Blueberry Scone Fail
electrolux137
Los Angeles
<div data-offset-key="77bmi-0-0" data-editor="f3sig" data-block="true">
<div class="_1mf _1mj" data-offset-key="e6se1-0-0"><span data-offset-key="e6se1-0-0"><span data-text="true">Purely on a whim tonight I tried my hand at making blueberry scones for the first time. I compared several recipes and chose the easiest one.</span></span></div>
</div>
<div data-offset-key="dl45m-0-0" data-editor="f3sig" data-block="true">
<div class="_1mf _1mj" data-offset-key="dl45m-0-0"><span data-offset-key="dl45m-0-0"> </span></div>
</div>
<div data-offset-key="cgc76-0-0" data-editor="f3sig" data-block="true">
<div class="_1mf _1mj" data-offset-key="cgc76-0-0"><span data-offset-key="cgc76-0-0"><span data-text="true">Well, they look delicious but taste, well...</span></span></div>
</div>
<div data-offset-key="3ao72-0-0" data-editor="f3sig" data-block="true">
<div class="_1mf _1mj" data-offset-key="3ao72-0-0"><span data-offset-key="3ao72-0-0"> </span></div>
</div>
<div data-offset-key="aip1q-0-0" data-editor="f3sig" data-block="true">
<div class="_1mf _1mj" data-offset-key="aip1q-0-0"><span data-offset-key="aip1q-0-0"><span data-text="true">I gave Arlee one; a couple minutes later he came in and said, "Something in this is tickling my throat." I also detected an odd, sharp taste. It was baking powder, even though I always use the non-aluminum kind. But too much is too much.</span></span></div>
</div>
<div data-offset-key="97qp0-0-0" data-editor="f3sig" data-block="true">
<div class="_1mf _1mj" data-offset-key="97qp0-0-0"><span data-offset-key="97qp0-0-0"> </span></div>
</div>
<div data-offset-key="2mr3c-0-0" data-editor="f3sig" data-block="true">
<div class="_1mf _1mj" data-offset-key="2mr3c-0-0"><span data-offset-key="2mr3c-0-0"><span data-text="true">They were also very crumbly and just fell apart. The only way to eat them was with a fork and even then they just made a big mess.</span></span></div>
</div>
<div data-offset-key="f326j-0-0" data-editor="f3sig" data-block="true">
<div class="_1mf _1mj" data-offset-key="f326j-0-0"><span data-offset-key="f326j-0-0"> </span></div>
</div>
<div data-offset-key="9n56s-0-0" data-editor="f3sig" data-block="true">
<div class="_1mf _1mj" data-offset-key="9n56s-0-0"><span data-offset-key="9n56s-0-0"><span data-text="true">I googled more recipes, and realized that the quantity of baking powder ranged from 2-1/2 teaspoons to 1 tablespoon. The one I followed called for 2-3/4 tablespoons! No wonder. It must have been a typo. ("Who knew?!")</span></span></div>
</div>
<div data-offset-key="1ccfj-0-0" data-editor="f3sig" data-block="true">
<div class="_1mf _1mj" data-offset-key="1ccfj-0-0"><span data-offset-key="1ccfj-0-0"> </span></div>
</div>
<div data-offset-key="554aq-0-0" data-editor="f3sig" data-block="true">
<div class="_1mf _1mj" data-offset-key="554aq-0-0"><span data-offset-key="554aq-0-0"><span data-text="true">So into the trash the whole lot went, meaning I wasted about $15 worth of ingredients.</span></span></div>
</div>
<div data-offset-key="3j581-0-0" data-editor="f3sig" data-block="true">
<div class="_1mf _1mj" data-offset-key="3j581-0-0"><span data-offset-key="3j581-0-0"> </span></div>
</div>
<div data-offset-key="80bvn-0-0" data-editor="f3sig" data-block="true">
<div class="_1mf _1mj" data-offset-key="80bvn-0-0"><span data-offset-key="80bvn-0-0"><span data-text="true">I have more blueberries and will try again with a different recipe that has a lemon glaze. I hope they turn out as heavenly as they sound!!</span></span></div>
</div>
From King Arthur flour site
<h2> Fresh Blueberry Scones.</h2>
<div id="volume_or_weight" class="ingredients-container"><!-- ingredientsContainer --> <!-- / ingredient-units-container -->
<div id="v_ingredients" class="ingredient-units-container animated fadeInDown" style="display: inline;">
<div class="ingredient-group" data-serverid="IngredientSet"><!-- ingredientGroup -->
<h4 data-serverid="IngredientHeading"> </h4>
<!-- ingredientGroupTitle -->
<ul data-serverid="ingred-parent">
<li data-serverid="IngredientLine">2 cups King Arthur Unbleached All-Purpose Flour or Pastry Flour</li>
<li data-serverid="IngredientLine">1/2 teaspoon salt</li>
<li data-serverid="IngredientLine">1/4 cup sugar</li>
<li data-serverid="IngredientLine">1 tablespoon baking powder</li>
<li data-serverid="IngredientLine">3/8 cup (6 tablespoons) cold butter, cut into pieces</li>
<li data-serverid="IngredientLine">2 large eggs, beaten</li>
<li data-serverid="IngredientLine">1/3 cup vanilla yogurt</li>
<li data-serverid="IngredientLine">1/2 teaspoon vanilla extract</li>
<li data-serverid="IngredientLine">1 tablespoon lemon zest (grated lemon rind); or 1/4 teaspoon lemon oil</li>
<li data-serverid="IngredientLine">1 cup blueberries, picked over and rinsed</li>
<li data-serverid="IngredientLine">2 tablespoons melted butter</li>
<li data-serverid="IngredientLine">2 tablespoons sugar</li>
</ul>
</div>
</div>
<div id="w_ingredients" class="ingredient-units-container" style="display: none;">
<li data-serverid="IngredientLine">8 1/2 ounces King Arthur Unbleached All-Purpose Flour or 7 1/2 ounces Pastry Flour</li>
<li data-serverid="IngredientLine">1 3/4 ounces sugar</li>
<li data-serverid="IngredientLine">3/8 ounce baking powder</li>
<li data-serverid="IngredientLine">3 ounces cold butter, cut into pieces</li>
<li data-serverid="IngredientLine">2 5/8 ounces vanilla yogurt</li>
<li data-serverid="IngredientLine">1/8 ounce lemon (grated lemon rind); or 1/4 teaspoon lemon oil</li>
<li data-serverid="IngredientLine">6 ounces blueberries, picked over and rinsed</li>
<li data-serverid="IngredientLine">1 ounce melted butter</li>
<li data-serverid="IngredientLine">7/8 ounce sugar</li>
</ul>
</div>
</div>
<div id="g_ingredients" class="ingredient-units-container" style="display: none;">
<li data-serverid="IngredientLine">240g King Arthur Unbleached All-Purpose Flour or 212g Pastry Flour</li>
<li data-serverid="IngredientLine">50g sugar</li>
<li data-serverid="IngredientLine">12g baking powder</li>
<li data-serverid="IngredientLine">85g cold butter, cut into pieces</li>
<li data-serverid="IngredientLine">74g vanilla yogurt</li>
<li data-serverid="IngredientLine">6g lemon (grated lemon rind); or 1/4 teaspoon lemon oil</li>
<li data-serverid="IngredientLine">170g blueberries, picked over and rinsed</li>
<li data-serverid="IngredientLine">28g melted butter</li>
<li data-serverid="IngredientLine">25g sugar</li>
</ul>
</div>
</div>
</div>
<!-- / ingredients-container --> <!-- / recipe-ingredients -->
<div id="instructions" class="recipe-instructions">
<h2>Instructions</h2>
<ol data-serverid="InstructionSection">
<li data-serverid="InstructionSet"><!-- please remove InstructionPhoto
--> <span class="recipe-instruction-span" data-serverid="Instructions">Preheat the oven to 375°F. Sift the dry ingredients together in a bowl. Add the butter and rub it into the dry ingredients with your fingers. </span></li>
--> <span class="recipe-instruction-span" data-serverid="Instructions">Stir the eggs, yogurt, vanilla extract, and lemon zest or oil together. Add to the dry ingredients and stir just until combined. Stir in the blueberries. This dough is the consistency of a wet drop-cookie dough. </span></li>
--> <span class="recipe-instruction-span" data-serverid="Instructions">Liberally flour your counter and your hands. Take the dough out of the bowl and place it on the counter. Pat it into a 1" thick rectangle. Cut into 10 triangular scones. Place on a well-greased cookie sheet. </span></li>
--> <span class="recipe-instruction-span" data-serverid="Instructions">Brush the scones with melted butter, and sprinkle with sugar. Bake for 20 minutes, or until lightly browned and a cake tester inserted into a scone comes out dry. Cool completely on a rack. </span></li>
</ol></div>
Arlee might accuse you of trying to
"off him". Witnesses.........
All kidding aside, poor Arlee.... your test kitchen. I made chicken cordon bleu...tried 4 different recipes until I liked one. My poor aunt ate those chickens for a month
WE got a scone recipe from the Little Sisters of the Poo. They sold them to raise funds. They were delicious.
omg guys I'm sitter here at work checking important emails ya know lol and I'm trying to be quiet until I read this post. I'm cracking up. Oh John, God bless typos!!!
