Best vacuum for small apartment without pets?
honestly,
I've tried to move as far away from bagless as I possibly can, with only a couple of exceptions. Bagless machines, to me, are a pain in the hind quarters and not worth the time you have to put into them to clean the damn thing after you use it. When I run any of my machines, I want to be able to turn it on, vacuum, and turn it off, not have to take it all apart and empty this, and tap the dirt off of that. I can change out a bag in one of my Luxes in 10 seconds flat. Dumping out a dust cup? My allergies try to kill me.
With some machines...
Namely, my Hoover Windtunnel 2 Rewind Pet and Bissell C4 Cyclonic canister vacuum, both have crappy dust bin designs that allow the dirt to get stuck in them and not come out when you open the bottom door. This necessitates lots of tapping to dislodge the debris, or pulling it out by hand. The constant tapping causes dust to collect on the outside of the bin, and then it has to be wiped down afterward.
On some machines, such as the Dyson DC07 and Eureka AirSpeed Unlimited Rewind, those bins are also bottom-empty mechanisms, but both are designed so that everything falls out when you open the bottom door. I prefer those kinds of dust cups, where there is no "lip" to trap debris.
why tap-out dirt when you can throw-away a bag?
Eh, my bagged vacs get dusty on the outside too, especially the floor brush and wheels. Dog hair and dust love to cling to aanything with a static charge. I will usually take the dusting brush and vacuum off the outside of the vac I am using and the floor brush before putting it back into the closet. At bag change I'll use another vac to vacuum out the bag chamber of the vac I am changing the bag in. Every so often I break out the can of Lemon Pledge and a soft, well worn rag and give my vacs a nice shine.
Update
Mom still can't afford a new vacuum right now. She just vacuumed today, without me. So I'm still at a loss.
After exhaustive research, I've narrowed it down to one of two choices:
1. Bissell Cleanview with OnePass, 9595, $80
2. Hoover Windtunnel Air Steerable, UH72400, $160
Ugh. Once Mom gets a new vacuum, she will return the Dyson DC07 to my house.
Niclonnic
Please don't take offense to this, but I personally feel you should fix up the Dyson, do whatever it needs done to it, & let your Mom keep it & you drop your ideas of trying to get it from her. You have a perfectly good Hoover upright at home that you could live with, & you just gave away a nice new Eureka Airspeed upright you got for free thru Amazon Vine. Your Mom DESERVES to keep this Dyson....she has had the heart to be a good mother to you & wife to your father, so your Mom deserves a nice cleaner, regardless of whether you feel it's "too much" cleaner for her. Love your mother, have a heart, leave her alone & let her keep the Dyson.
Now, to solve your problems you have had with your Hoover. Here's something to consider....how about trying a bagged vacuum & using a Kevlar cloth shake-out bag instead of paper bags? The material these bags are made of is the same as Kirby makes their outer vacuum bag. You simply take the bag out, remove a plastic slide at the bottom of the bag, empty & put back into your vacuum. After a few times filling it up & emptying it, you can hand wash in the sink & let air dry. Of course it would be a good idea to take the bag & trashcan outside to empty it. One big advantage to using a shake-out bag is that it can hold a LOT more dirt than most bagless vacuum's dirtcups before needing to be emptied. And of course you could always use a paper bag if you had a big messy job & you didn't want to be exposed to the dirt.
Panasonic makes a pretty good upright....the upright I have linked here has been in production under Panasonic & Kenmore names since the mid 1990's, so it's a proven design that won't give you problems. If you would prefer to have a HEPA filter, though, then you could buy the Carpet Pro upright & also buy the Fuller Brush HEPA filter & use that with the upright. Or, you could also buy the Fuller Brush version, main difference between the two being is the Fuller Brush has a metal handle which you don't need, & also looks like the hose may be longer & the cleaning wand is attached, same as the Panasonic design. You could also buy a Kenmore upright that takes the 5068 bag, as the Panasonic Type U can be used in them, but be warned the HEPA filter is not sealed like the Carpet Pro or Fuller Brush machines would be, lots of dust would escape around the filter.
If you're going to be stubborn though, & wouldn't give the idea of a shake-out bag a try, & you MUST have a clear bin, there's one option left to consider, & this would completely eliminate the bottom-empty dirt cup design....the Dirt Devil Breeze upright vacuum. It's an effective design & works very well on carpets & floors. When you look at the underside of the powerhead, the reason is obvious....the intake tube is HUGE, & it's been designed so most of the powerhead is exposed to the airflow, it's not off to one side like most clean-air uprights. Consequently, it picks up the dirt quickly & carries it away to the dirtcup, & picks up dirt off floors without scattering it too much like most powerheads would. This design also incorporates a wide powerhead hose, & a short air pathway to the dirtcup, it's highly unlikely to clog. To empty, you just take the bin outside, take the top off, dump into the trashcan, then clean the filter by "wringing" it with your hands. Another way to clean the filter would be to find a large stone & keep it, then take your filter, put it in a shopping bag, bang the heck out of it, tie it up & then use it again next time the filter needs to be cleaned. The filter can also be washed occasionally. I wouldn't worry about buying filter replacements, the filter should last the life of the vacuum, & the F1 HEPA filter, which is identical, the filter material isn't any better than the Microfresh filter the Breeze is supplied with. Now there are some downsides to this cleaner though.... 1. It is fairly noisy. However, after using one myself, I didn't find it too bad, you could get used to it, & for some reason being noisy does seem to be a trait of Dirt Devil vacuums. 2. The tool attachment hose has to be hooked up & unhooked to the main powerhead hose every time you want to use attachments. However, considering the advantage is a short air pathway & no clogging, I would live with it. You could always just do your whole house, then hook up the hose & do what you need to do with the attachments.
Now, be warned though....DO NOT buy the newer version of this vacuum at the bottom of the Amazon link!! Horrible design! I had to help a friend out with one of these, & they moved the filter from the dirt cup & made it smaller, presumably to make it easier to clean. Well, instead it clogs way too easily & is a nightmare to clean. Hate to say it, but this one puts the "devil" name in Dirt Devil :-). The older version I recommend above is discontinued, but Dirt Devil just recently had a clearance on it thru the Hoover website, & can occasionally be found on Ebay & other websites, you'll just have to hunt for it. Also, the older version has been made for years under other names....Breeze, Featherlite & Jaguar are the most common names, & there is also a black Regina version too. You can tell if it's an older model if there is no headlight, they only put that on the last couple of years it was made. So you could find one easily at a garage sale or thru Craigslist or Kijiji too. Most I would pay for one would be $30, since in most stores it sold for $100 & went on sale for $50, so since most people would buy it on sale & pay just under $60 including taxes, $30 is reasonable.
Hope this helps you out, Niclonnic.
Panasonic upright http://www.amazon.com/Panasonic-MC-..._hg_vf__3?ie=UTF8&refRID=164P7EGD6ZY83Q7HG6TR
Carpet Pro upright http://www.amazon.com/Carpet-Pro-CP...215?s=vacuums&ie=UTF8&qid=1410782933&sr=1-215
Fuller Brush upright http://www.amazon.com/Fuller-Brush-...724?s=vacuums&ie=UTF8&qid=1410784945&sr=1-724
Fuller Brush HEPA filter http://www.amazon.com/Fuller-Brush-...388?s=vacuums&ie=UTF8&qid=1410784239&sr=1-388
Panasonic Type U shake-out bag http://www.amazon.com/Panasonic-Upr...10786131&sr=1-39&keywords=Panasonic+cloth+bag
Dirt Devil Breeze upright http://www.amazon.com/Dirt-Devil-Ba...166?s=vacuums&ie=UTF8&qid=1410782849&sr=1-166
Well, Rob...
I may agree with your first paragraph there. However, Mom vacuums only on occasion and doesn't really care about what she uses. It's a bit frustrating, considering I have a lot of nice things in my house. After all, a Dyson Animal is designed for pet owners in houses. Spending $500 on a vacuum for a small apartment without pets is ridiculous. $100 or less is more like it.
The Eureka AirSpeed that I had was given to my dad's friends, whose vacuum just died and they couldn't afford a new one. They were ecstatic to see a practically brand-new vacuum, and they love it.
I now have a Bissell C4 Cyclonic canister vacuum, also a freebie from Amazon Vine. As a guy who has always used uprights, using a canister vacuum takes some getting used to. I'm used to rolling the vacuum out of the closet, plugging it in, turning it on and pushing it over the carpet. Now I have a few more steps, as the Bissell canister is stored in 3 pieces: Main motor/dirt tank unit, hose, and power foot/telescopic wand. But it is SO quiet and a lot more maneuverable compared to an upright. I can actually get under BEDS using this vacuum!
Now, about my Hoover issue. Replacement dirt cups cost $37.40; unfortunately, they're still on backorder and out of stock. I find this outrageous! It seems that every time my family buys a Hoover, they always fall apart. I have read other reviews online, where this has happened to some other people. If I had to have a budget vacuum, I would choose a Bissell. I have always had good luck with Bissell products.
I'll admit that I'm a pretty stubborn individual, as I've never been a fan of bagged vacuums. I don't want another Dirt Devil, as I've owned one from 2001 to 2004. The Devil made my parents buy it! It was very noisy, very heavy, the filter clogged easily, and it smelled AWFUL, even when not being used. Mom even managed to break a belt on it. Luckily, there was a spare belt on the back of the cleaner, stored on the special belt storage area.
I'm not going to buy a used vacuum.
As for the two vacuum suggestions, here are my thoughts of the Bissell and Hoover machines I'm thinking about, based on my research:
1. Bissell Cleanview with OnePass: http://www.amazon.com/BISSELL-Clean...80305?s=vacuums&ie=UTF8&qid=1410801354&sr=1-1
Most owners love it, saying that it's lightweight, cleans carpets well and is quiet. However, it has rudimentary dual-cyclonic technology, meaning that the foam pre-motor filter will get clogged easily. Brushroll can't be turned off, so not ideal for bare floors. Short, stiff hose. Includes turbo brush. Power switch is in an awkward location.
2. Hoover Windtunnel Air Steerable: http://www.amazon.com/Hoover-WindTu...1_26?s=vacuums&ie=UTF8&qid=1410801507&sr=1-26
Looks to be a good buy. Has brush roll on/off setting. Multi-cyclonic, with 8 cyclones. Lightweight at 14 lbs. Steerable technology allows for easier vacuuming. However, the canister is small. The hose, while long, must be hooked up in order to use the attachments. Attachments are lacking; only comes with 2-in-1 crevice tool and dusting brush. No turbo brush included.
Nic, Have you considered the Air PRO Steerable?
[COLOR=#666666; font-family: Arial, 'Helvetica Neue', Helvetica, sans-serif; font-size: 12pt; font-weight: normal]The differences between the Air Steerable and Air Pro Steerable are: The Air Pro UH72450 dust receptacle has a larger capacity, and it comes with the turbo tool that the Air Steerable UH72400 does not have. The Air Pro also has 12 cyclones versus the 8 cyclones for the Air Steerable. The cyclones keep the dust from clogging the filter and prevents loss of suction. You do not have to disconnect the hose to use the tools. The Air Pro has a dial that switches the vacuum from floor cleaning to using the tools. The dial can be used to limit the strength of suction when vacuuming door mats and small rugs by turning the dial away from floor towards the tool setting.[/COLOR]
http://www.amazon.com/Hoover-Air-Bagless-Upright-UH72450/dp/B00B786TXG
Hmm...
The Windtunnel Air Pro seems to be designed for homes with pets, due to the larger canister and included turbo brush.
The Steerable model would be more suitable for an apartment, due to its more compact design.
Maybe you should just let Mum have the Dyson and you buy a used vacuum for yourself when you save up enough money. Surely you can clean up the dyson and get rid of the smell.
You said: "Spending $500 on a vacuum for a small apartment without pets is ridiculous. $100 or less is more like it." I'd disagree. The Dyson seems perfect for your Mom. Besides it's used, so it's value is really more like $100. Why shouldn't your Mom deserve a Dyson?
If you want the Dyson so badly, buy your mom a reasonable replacement if she agrees to the trade.. otherwise, grow up and buy your own someday. It's not your house, it's your father's and it's not your vacuum, it now belongs to your mother. You're a greedy little boy who wants things he can't afford for himself and thinks his parents should just give you what you want... life is so not going to be good for you out in the big bad world....
Some points to make
Ralph123, I do currently own two fairly recent vacuums: a Bissell C4 Cyclonic canister vacuum and a Hoover Windtunnel 2 Rewind Pet. Both vacuums were freebies from the Amazon Vine program.
The Bissell canister takes some getting used to, especially if you're used to uprights. However, this vacuum is very quiet and more maneuverable compared to an upright. If you have a lot of carpeting, it can be a pain to use, because you have to drag the main suction motor part of the vacuum behind you. Plus, the cord is rather short.
The Hoover upright does very good at cleaning carpets. I ended up using it more than the Dyson because it does better at carpet cleaning. However, its hose is VERY short, and the extension wand is also very short. Also, it's made very cheaply. Here is a list of the various parts I've had break, etc.:
1. The wheels started to squeak after using it for a while.
2. The cord clip broke off after 6 months.
3. The cheap plastic hinge on the dirt cup broke after 10 months. So every time I go to empty the vacuum, the bottom flap falls into the trash can. Replacement dirt cups cost $37.40, but they're out of stock as of the time of this writing.
In the end, a Dyson Animal is ideal for homes with pets. My DC07 Animal, which is nearly 7 years old, has been used for 6 years about once a week, in my 3 bedroom 1800 sq. ft. house with a few dogs, a few cats (2 cats which have passed away several years ago) and a family of four (including myself). That machine was a workhorse! It has NEVER lost suction, nor needed any replacement parts during this time. It was $500 from Target, and it has paid for itself many, many times.
Gr8DaneDad, I am NOT greedy, being 20 years old. At my house, we have a lot of nice things, namely, an LG front-load washing machine and a Samsung stainless steel French door refrigerator. It baffles me that Mom would take an overpriced "Animal" vacuum to a small place that doesn't even have pets! Plus, due to the bad smell that the vacuum gives off during use, she has asked for a new one. Once Mom buys a new vacuum someday, she will return the Dyson to us.
My life is hard...
I'm not sure
The Air Steerable is a bit expensive for this situation. I'm considering a different vacuum this time:
The Eureka AirSpeed All Floors, AS3011A. This vacuum is available exclusively at Walmart for $98.96. It is similar to the Eureka I had that my dad gave away, but this one doesn't have the cord rewind mechanism. That was a very impressive vacuum. It does an excellent job on both carpets and hard floors. This vacuum features an on/off brush roll switch that'll be great for cleaning up crumbs from the kitchen, and picking up hair from the bathroom.
This vacuum is bagless, and is also dual-cyclonic, so it'll never lose suction. However, Eureka's dual-cyclonic technology is inefficient, and as a result, the pre-motor filter above the dust cup gets clogged with dust quickly. The dust cup is easy to empty, with a bottom-release mechanism.
The vacuum comes with a turbo brush that would be nice for vacuuming the bed, along with the dining chairs.
Overall this Eureka is very impressive for the price. For just under $100, it's hard to go wrong, so I'll recommend this vacuum to my mom.
http://www.walmart.com/ip/Eureka-AirSpeed-All-Floors-Bagless-Upright-Vacuum-AS3011A/34171462
Why would you have your mom buy a cheap plastivac that will break down and end up in the dumpster in a couple of years?
Isn't she worth at least the price of the Windtunnel Air Steerable which will last 7-10 years?
At this point, Niclonnic,
I personally would have given my mom one of my nicer vacs, perhaps my Electrolux Ultralux LX canister, or my Hoover Convertible U4387. I would never cheap out on anyone, ESPECIALLY my own mother. You, sir, have some convoluted values. If I were her I'd start looking elsewhere for a nicer vacuum than the "Wal-Mart Special" you recommended to her. Nothing says "I love you, mom" like a Walmart plasti-vac.
Well ...
Depends on your budget.
$500 to some people is like $10 to others.
I spent $1,600 on a vacuum for my small-ish apartment. Was that ridiculous? I don't think so. But then again, my financial situation is quite different from someone, for example, for whom $1,600 is their entire monthly income.
I had....
A Hoover Nano Cyclonic. It was from Target and I absolutely hated it. The only thing that I hated was the wand, where there was a crevice tool glued to it so that it could not be removed. Washing the filters on it, SHEESH shouldn't have even bothered getting it. Just my opinion.
Nano cyclonic isn't the way to go. Spring for the Hoover Tempo!
Nick
No offense, but...
NYCWriter, Mom has to pay the rent regularly at her apartment, so she has a relatively low budget. In a small apartment with no pets, her vacuuming needs are very basic, but she can't afford one yet.
Nick, you have the same name as me! Anyway, the Hoover Nano Cyclonic is available at Walmart, but I don't want Mom to buy a new vacuum from there. Also, she doesn't want a bagged vacuum.
Ralph123, before I let Mom "borrow" the Dyson, I rinsed the pre-motor filter, along with the clear bin. I didn't rinse the cyclone assembly, as Dyson does not recommend it. I also wiped down the machine really well with damp paper towels, but it still gives off a dog smell every time it is turned on. I can't really get that smell out...
I'll recommend Dyson to cram it, your machine is out of warranty, anyhow! I've washed cyclones in my day with no trouble. Wash the cyclone out with the garden hose, then soak it in a bath of cleanser. Let it bake in the sun for a few days, turning it upside-down half-way trough the baking process! Then you're done!
Hmm...
I don't know about washing the cyclone assembly with water, but I've been thinking of a different way to clean out the cyclones.
What I'm considering doing is this:
1. Remove the 3 Torx screws on top of the cyclone assembly.
2. Lift out the top of the cyclone assembly, which includes the long rod.
3. Take my Ridgid shop vacuum and plug the hose into the blower port on the back.
4. Attach the crevice tool to the hose.
5. Turn the shop vac on.
6. Using the shop vac, blow all of the dust out of the cyclones.
7. Put the cyclone assembly back together.
Hopefully, I'll give this method a try sometime.
That will not remove the smell, only the dust. The vacuum will still reek of dog if you only blow it out!
Your best bet is to soak it for a day or two in a bucket of cleaning solution after dissembling the cyclone the best you can.after soaking, scrub the cyclones with a Brillo pad, then power-rinse the assembly until the water runs clear.
