Anyone here with a Eureka 3.35 amp motor?
superocd
PNW US
I can't find anything anywhere about this motor. What should a 3.35 amp Eureka motor look like? I'm restoring a Sanitaire 641 and that is the motor it should have per the data plate, but the motor in my 641 looks suspiciously similar to the common 7-amp Sanitaire motor with the metal bearing plate, though it has "3373" stamped on the upper bearing plate, and 1973 is the year of manufacture for this particular machine, so I'm not sure if it's a date code or something else.
Could anybody tell me more about this motor?
I
May have a motor your asking about. I'll check tonight. The motors I believe 3-3.5 amp are the same configuration just upgraded every couple years. I'll double check my vacuum and let you know.
