And the Mystery Continues......
dysonman1
the county
I recently acquired a machine from the Ukraine (which arrived in a potato bag - seriously) that only deepens the mystery.
It's a virtual copy of the McAllister Bagless as well as the ConVac. The McAllister came out soon after World War II was over, and a design patent was obtained in 1950. The machine had a cloth filter between the motor and the pan, making it 'bagless'. It's a filthy mess to empty. According to a magazine article from around 1948 about the "post war" models, this was described as being a wet vac as well. No grounding pin of course, and a flow-thru motor. Talk about shocking.
I do not know when the McAllister-Ross Corporation stopped making the McAllister - but they did only have the one model.
All of a sudden, the ConVac hit the market. Still made in Chicago, but by an entirely different company.
Then, the ConVac went away (only know of one model) - and soon afterwards, the Fairfax was launched. Fairfax had a deeper pan to hold a disposable bag.
The Ukraine model, which is a copy of the first two, is dated 1962 (after Fairfax's launch).
I took the top dome off to see what a Russian motor looks like. They have a metal 'chain' from the carbon brush holder cap to the field coil. Looks like a Lamb motor copy, but, the commutator on the armature has a ton of segments (28). I have no idea what the words say.
All three together for a glam shot.
I don't know how they are related, or anything at all about the companies that made them. All three run, the Ukraine machine has a TON of suction (it's 220 volts).
Probably a Soviet era knockoff
Given the fact the 'McAllister' is misspelled on the name plate, my money's on it being a Soviet era knockoff. Rather than completely develop a product from scratch, they would often buy tooling from Western countries for recently discontinued products. That's why they were building mid-'50s Packard automobiles in the USSR well into the 1970s. While these products typically got Russian names, sometimes versions would be made that were essentially counterfeits of the original. My dad has a "Leica" camera he bought at a Moscow flea market that has a Leica logo--and a Nazi emblem--on it. The only problem is the camera is a common Soviet knockoff, usually seen with a Russian name, but some were made with Leica logos as black market fakes. The Nazi emblem was likely added after the fact to lend it an air of authenticity.
Some of the words are just name and I cant make out one letter in the first word but this is approximately the translation.
L_IESOS
EL-2
LANCE-NARKOZ
ZA 80D
ZLEKTROMET
NAPRYAZHENIE (VOLTAGE)
220 V
MOSCHNOST (POWER)
500 W
VILUSK 1965 (RELEASE 1965)
ZAVODSKII (DISTRICT OF MINSK, BELARUS)
So, my Vac-U-Tronic Tester has various machines listed on the back, and the performance in inches of water for that period of time....'50s. The 'McAllister-Ross' was listed @64"-70". That's the strongest by far, except for a GE tank that was 60"-66". I can't make out the model except for the first two #s....81___(spot of paint rust right there).
Is it true that the "McAllister-Ross" made those kinds of numbers?
Kevin
Kevin
The GE was probably an 815, which would've been new at the same time as the McAllister bagless. The McAllister just used a lamb motor like the compact C – 2 or the Lewyt 44. They all had the same suction. I have all three of those machines, getting ready to go up on the block.
My tester says the Lewyt 55101@55"-60" and the 5580@55"-61". The 44, I'm guessing maybe came later?
The Lewyt 40 and 44 used the old style lamb motor made right after the war, up through 1955. The new style lamb motor was used from 1955 on by Eureka, Lewyt, Compact, after 1958 by Sears. They all used the same motor.
