Copper/brass
The copper/brass screws are where the two cord leads get mounted and secured. If you have the cord where the leads go I'd use wire connectors attach them to the posts.
Having copper leads bare is risky. I'll tell a story to understand better. I had a Dodge ram charger 1976 with a 440 and Edelbrock carb. It had a circular Edelbrock air filter. It was three pieces. Top filter bottom.
The top and bottom are aluminum.
The battery has two leads on it positive and negative. I touched the positive terminal with aluminum top plate. It arced sparked and the 18 inch diameter top plate got 3 places it disinigrated aluminum. They were silver dollar sized holes. The melted aluminum was on terminal welding the plate to the terminal.
Electricity arcs on metal and it also gives the metal an electric charge.
I think you understand now.
There is an airway special 37 on eBay. I'm not mentioning more as I hope to buy it in a week or 10 days.
The airway was ahead of it's time.
Alex Taber and Tom gasko give history of airway in archive section. It's where I learned about them.
Carbon brushes with grease is bad. Get dish soap and maybe a tooth brush and gently clean. Grease is an excelerent. If you get carbon brush spark it will ignite. The tempature is 1200-1600 degrees. It's pretty blue , green and a flickering yellow. I arced out 2 d80 motors after long restore project.
