A Canine Guest Visits Casa Electrolux
electrolux137
Bronze Member
Los Angeles
<div data-contents="true">
<div data-offset-key="efifm-0-0" data-editor="e6sua" data-block="true">
<div class="_1mf _1mj" data-offset-key="efifm-0-0"><span data-offset-key="efifm-0-0"><span data-text="true">We had a cute canine guest here at Casa Electrolux today. A neighbor's dog was on the lam. When I saw him trotting right in the middle of the road I went after him. He played chase at first but finally came up to me. I got his owner's info on his tag and called; she'll pick him up later today.</span></span></div>
</div>
<div data-offset-key="9o2ba-0-0" data-editor="e6sua" data-block="true">
<div class="_1mf _1mj" data-offset-key="9o2ba-0-0"><span data-offset-key="9o2ba-0-0"> </span></div>
</div>
<div data-offset-key="a4qqd-0-0" data-editor="e6sua" data-block="true">
<div class="_1mf _1mj" data-offset-key="a4qqd-0-0"><span data-offset-key="a4qqd-0-0"><span data-text="true">I didn't want to let him roam loose in the apartment because I didn't know if he has fleas or is housebroken, so I put him on the balcony where, after a bit of barking and whining, he finally settled down.</span></span></div>
</div>
<div data-offset-key="8iull-0-0" data-editor="e6sua" data-block="true">
<div class="_1mf _1mj" data-offset-key="8iull-0-0"><span data-offset-key="8iull-0-0"> </span></div>
</div>
<div data-offset-key="fehtb-0-0" data-editor="e6sua" data-block="true">
<div class="_1mf _1mj" data-offset-key="d7iro-0-0"><span data-offset-key="d7iro-0-0"><span data-text="true">Of course, Doggie and LoLo were quite perturbed, especially LoLo because he was the object of our guest's unwelcome affections -- and made it perfectly clear that he wasn't interested!</span></span></div>
<div class="_1mf _1mj" data-offset-key="d7iro-0-0"> </div>
<div class="_1mf _1mj" data-offset-key="d7iro-0-0"><span data-offset-key="d7iro-0-0"><span data-text="true">A little while later I took them all back outside and they got along fine and all made poo-poo. When we came back up Doggie and LoLo were already bored with him and just wanted their treats.</span></span></div>
</div>
<div data-offset-key="dsm6h-0-0" data-editor="e6sua" data-block="true">
<div class="_1mf _1mj" data-offset-key="dsm6h-0-0"><span data-offset-key="dsm6h-0-0"> </span></div>
</div>
<div data-offset-key="dot9b-0-0" data-editor="e6sua" data-block="true">
<div class="_1mf _1mj" data-offset-key="dot9b-0-0"><span data-offset-key="dot9b-0-0"><span data-text="true">I won't stand too much in judgment of his owner except to say I've seen the dog running loose several times lately, and he is not neutered. I mentioned to the lady that she might want to secure him better and to get him neutered ASAP. I said he could easily get run over, get dognapped, get into a fight with territorial dogs, or get picked up by Animal Control.</span></span></div>
</div>
<div data-offset-key="5cui5-0-0" data-editor="e6sua" data-block="true">
<div class="_1mf _1mj" data-offset-key="5cui5-0-0"><span data-offset-key="5cui5-0-0"> </span></div>
</div>
<div data-offset-key="5bi3g-0-0" data-editor="e6sua" data-block="true">
<div class="_1mf _1mj" data-offset-key="5bi3g-0-0"><span data-offset-key="5bi3g-0-0"><span data-text="true">He's a very sweet, easy-going and affectionate dog. I hope she will take better care of him.</span></span></div>
</div>
</div>
<div data-offset-key="bcei8-0-0" data-editor="84qts" data-block="true">
<div class="_1mf _1mj" data-offset-key="bcei8-0-0"><span data-offset-key="bcei8-0-0"><span data-text="true">POSTSCRIPT...</span></span></div>
</div>
<div data-offset-key="6oa26-0-0" data-editor="84qts" data-block="true">
<div class="_1mf _1mj" data-offset-key="6oa26-0-0"><span data-offset-key="6oa26-0-0"> </span></div>
</div>
<div data-offset-key="aeqov-0-0" data-editor="84qts" data-block="true">
<div class="_1mf _1mj" data-offset-key="aeqov-0-0"><span data-offset-key="aeqov-0-0"><span data-text="true">The neighbor to whom the curly dog belongs dropped off a very thoughtful thank-you card with a sweet note and two movie passes. I thought that was really nice of her.
</span></span><span data-offset-key="aeqov-2-0"><span data-text="true">
</div>
</div>
