Advice On Karcher hard floor cleaner
kirbyman65
USA
Hello!
A relative of mine is looking for a cheap and easy way to clean her laminate floors. After some research we settled on a Karcher FC 3 floor cleaner. It's perfect for what she needs. The only question she had was what can she put in it besides water (and not a strong chemical) I know you can't use dish soap because it foams up too much, is there any cleaning products you can use in it besides the solution?
Also, has anyone tried one?
-Jack
https://tinyurl.com/4e4m7xa3
I use a Lindhaus LS38 hard floor sweeper vacuum. I can also use the hard floor tools with my canisters. I was told by the home salesman NOT to wet the laminate flooring. The water can get between the planks causing them to swell. I wipe up liquid spills with. A rag or sponge.
I think the better floor washer is the Hoover Streamline. But in any case, with the Karcher, you should only use the cleaning fluid sold by Karcher with the cleaner. Companies that sell these floor washers design specific formulas that are compatible with the brush roll in the machine and that are compatible with the design of the rest of the machine.
