fantomfan57
I am looking for a wiring diagram for my new machine. After inspecting it I found only one problem. The power cord was loose from the unit body.
I took the machine apart and struggled with keeping the two halves steady while I worked on the cord. I cleaned and re-glued the cord stress sleeve back where it had separated. I am pretty sure I reconnected everything back as before.
When I plugged it in, I tripped the power strip. I took everything apart again, stripped the power cord from the stress sleeve and replaced the cording in that section with cording from beyond that point.
Tried it out and the fuse blew again. I bypassed the switch and nothing.
Did I ruin the motor? did I incorrectly bypass the switch.
Does anyone have a wiring diagram for a Tristar CXL vacuum?
