Worked out ok with Model xxx
Hi Andy,
The changing of the small cord from the cord winder to the canister was a success. All I had to do was remove the small cap with the nut on top and it exposed the wires. See the picture.
Did you remove this cap when you took apart yours? Alex was correct about removing to expose the wires.
I tested it and the machine ran normal. Instead of using this one on the LX, I used it for the xxx. Another cord winder is coming Tuesday for the LX which has the correct plug. So I am good to go with both machines. To be on the safe side, since I cut the original cord, I ordered another Model xxx power cord in case this cord winder breaks or is stolen...lol
Hi Andy,
