Sandy:
I had a similar situation with my mother's Epic 6500. Unit would run fine until any resistance/strain would be placed on the motor, it would shut off. It was actually the adjustable valve that was causing the problem. I'm not to sure about the model 1205, but I do believe the valve is the same style as the 1521 series canisters, in which case similar to the plastic canister valves. When you turn the adjustable valve, on the stem, there is a small rubber O ring that is surrounded on the top and bottom with a plastic flange, what happened with ours is that the plastic flange cracked, preventing the O ring from making a proper seal. What I did to determine the problem, disconnect the air line to the switch (plastic canister), or in your case the power diaphragm that pulls the door open, if your 1205 runs fine after this, I'd be looking at replacing/checking the adjustable valve.
Hope this is of help
Vernon
Vernon
