Dyson Piston
I was thinking, the V16 reaches 900W only in boost mode, without electric head and when the air openings are blocked, so only in case of stress, but is there a rule that says that this value can be hidden on the machine and write 450w instead of 900W? Maybe for some regulation writing 900w is illegal for some legal energy rules? And so they simply said the thing in marketing
For example, in the EU vacuum cleaners that exceed 900W are prohibited
A vacuum motor uses more watts when airflow is unrestricted. When airflow is restricted, the fan(s) is(are) unloaded. That reduces the power required to spin the fan(s). When you look at performance charts for vacuum motors you see this. As the orifice is restricted, motor rpm rises while amps and watts consumed both decline.
I've seen plenty of old Kennys with Ametek motors pushed past their thermal limits. Warped / melted bodies, burned commutators with melted segments smeared across each other. Turn it on and it sounds like ball bearings in a blender O_O
Besides that, I think it's very useless trying to force a product that was born, built, and sold in a certain way. We should just accept that Dyson made this decision for this release.
I also remember the V10; it was definitely a game changer. Then with the V11, they perfected all the starting material and improved the quality. The V16 is just the first attempt to better future products (I hope).
Number one, you don't preload a ball bearing. That is only for tapered roller bearings.
You absolutely do preload ball bearings for several reasons. One of those reasons in high speed applications is to make sure the balls roll rather than slide.
Those spring washers you usually see on the closed end of motor housings are for preload.
https://www.nsk.com/tools-resources/abc-bearings/preload/
https://vehicleaftermarket.skf.com/...1968065f1f4-Bearing-preload_tcm_12-299896.pdf
https://www.ntnglobal.com/en/products/catalog/pdf/2203E_a08.pdf
https://cdn.skfmediahub.skf.com/api...edium/0901d19680495562_pdf_preview_medium.pdf
I can, and it changes nothing. If you think there is an idea of value and relevance, just write it here instead of posting a 55 long minute video.
@Hatsuwr here:
Vacuum cleaners use a motor to spin an impeller, removing air and lowering internal pressure. This creates a partial vacuum, causing atmospheric air to rush in and drag dirt with it. According to Newton’s Second Law, dirt particles are accelerated when air moving into the cleaner head exerts a force on them. This drag force is influenced by the particle's shape, size, and the speed of the air. Then there's Venturi effect: by sealing the cleaner head to a surface, the walls act as a flow constrictor. This increases air speed as it enters narrow openings, which maximizes the drag force on dirt particles.
Crucially, suction pressure determines air speed, which drives cleaning performance. High airflow (at least according to @Vacuum Facts - as per @cheesewonton's suggestion, it depends on how limited the airflow is - in the case of cordless vacuums, it is limited enough because the motors are fed from batteries) is often incidental and not the primary factor in effective dirt removal. @Vacuum Facts used an analogy to electromagnetism to hammer the point home:
- Suction ≈ Voltage: It is the "pressure" that drives the system.
- Airflow ≈ Current: It is the volume of air moving through the circuit.
- Carpet ≈ Resistor: The flooring resists the flow of air. Hard floors have virtually zero resistance, while shaggy rugs (like the ones that's used to wrongly test Kirby machines) still have little resistance. Only backed carpets used in most homes have significant resistance.
- The motor itself has internal resistance, meaning some energy is always lost. On the other hand, leaks on the floorhead wool reduce the resistance drastically, due to being the path of least resistance.
Air watts measures the actual power of the moving air suction times airflow.
[AW] = c×F×S
0.117354×[CFM]×[kPa]
0.248659×[l/s]×[kPa]
0.0619×[l/s]×[in.H2O]
0.0292×[CFM]×[in.H2O]
Manufacturers often advertise (motor) Watts (electrical consumption), but Air Watts is the true measure of performance. However, AW alone is primarily there for above-floor/crevice cleaning. If the cleaner head seal is broken, air takes the path of least resistance (as mentioned above). This "leakage" causes a drop in suction pressure, which significantly reduces cleaning efficiency.
Different flooring have different interactions:
- Head Clamping: If suction is too high, the weight of the atmosphere can pin the head to the floor. Bleed gates (like the ones on Dyson's brush bars) or power modes are used to alleviate this while maintaining sufficiently high air speed.
- Agitation: Rotating brush bars provide three benefits: grabbing surface hair, opening gaps in the carpet pile to allow faster air within the pile, and shaking trapped particles free.
- Carpet Types: Backed (non-porous) carpets block air from underneath, making deep dirt harder to reach, whereas shaggy (porous) rugs allow air to flow through the backing but often require more power to maintain suction. As mentioned, backed carpets are used in most homes and also harder to deep clean, and thus is significantly more representative.
The evolution of vacuum cleaners necessitates better systems:
- Bags act as mechanical filters but lose suction as they fill with dust and become more resistive. In other words: they clogs and lose suction.
- Cyclonic tech: exclusive to bagless machines. Uses the Venturi effect to create high-speed jets that spin dirt out of the air. This ensures consistent suction regardless of how much dirt is in the bin. While Filter Queen invented the basic tech in early-to-mid 20th century, Dyson was the pioneer with the invention of a proper cyclonic separation system with multi-cyclonic design (inspired by industrial cyclones for factories).
- HEPA filters use processes like interception and Brownian motion to capture microscopic particles down to 0.3 micrometer at the largest, with at least 99.95% efficiency. Make sure the machine is fully-sealed, for the allergy-countering whole-machine filtration. (Dyson excelled on filtration in vacuums, now with down to 0.1 micrometer with a whopping 99.99% efficiency)
- New designs like rotating disc separators or non-cyclonic inertial systems (i.e. as used by PencilVac and V16) aim to be more energy-efficient and prevent hair tangling in the bin. Ditto more Archimedes screw designs (again, de-tangles hair pretty much flawlessly).
@Vacuum Facts also debunked a bunch of myths surrounding the vacuum cleaners:
- "More Airflow is Better": Large leakage airflows actually reduce suction and air speed, making cleaning worse. You gotta balance suction and airflow with suction being the main priority.
- Vibration: Excessive/violent vibration or "sand" bouncing outside the head (like what Kirby vacuums tend to do) is often a marketing trick and doesn't improve actual dirt removal under the head. You needs proper agitation and pile separation to do the job.
- Sand vs. Dust: Testing with only sand is unrepresentative, as fine household dust behaves very differently and is harder to remove. That's why @Vacuum Facts and the likes (and likely many others) didn't just use full sands.
- Big mess tests: Cleaning an absurdly large pile of dirt is "cosmetic entertainment" and doesn't prove a machine can remove deep-seated, real-world dust concentrations. If anything, it could potentially clog even a powerful stuffs with the most advanced cyclones ever, partly because it's so easy to overfill (not recommended at all; the content could overflow to the filtration systems, overpowering the cyclones and thus clogging the filters afterwards). Only a backed carpet with properly (not excessively deeply) embedded fine-mix dust eventually across would've done the job.
@Hatsuwr you asked for a recap, so I said what @Vacuum Facts talked about.
I just wish that it would be comprehensible to everyone how ridiculous this whole V16 situation is.
@centralsweeper63 precisely!
Airflow in cordless vacuums are relatively limited because the motors could only be powered by batteries which have limited capacities.
Somehow Dyson will have to refresh the V16 to fix the real issue @Vacuum Facts and partly @frickhelm spotted...
It already runs at 139,000 RPM (likely at 450 watts), increasing that would make it explode extremely quickly.
V16's motor maxes out at 140,000RPM.
Dyson bearings. Apparently.
No, Dyson's motors doesn't use such dedicated bearings. Their precise design and near-non-existent tolerance make friction and load reasonable for their supreme speed (140,000RPM currently). So I don't think the preload applies to Dyson motors the same way it does in other uses.
I did not ask for a recap, and I'm not reading all of that lol. I don't think much of VacuumFacts' opinions in the first place, but if you want to discuss something he brought up, I'd be willing to do so as long as it is relevant and has your own thinking included. Also, maybe not 100 things at the same time.
As far as the bearings go, I highly doubt Dyson uses 'standard' bearings for their recent stick vacuum motors. Even with good balancing and proper (pre)loading, at those speeds you still have to make some considerations regarding lubricant, materials of construction, tolerances, shielding/sealing, etc. if you want a reasonable life out of them.
'Standard' doesn't really mean anything specific, but I'd contrast it with something like an Ametek motor, where you could just pick up any decent quality sealed bearing of the right size from a reputable manufacturer and generally expect it to work well.
Would be interesting to see a disassembly of a V11 or V15 motor.
That spring is to control any end play and vibration in the armature. I have put countless tapered roller bearings and ball bearings into car and motorcycle wheels. With tapered roller bearings you have to very carefully preload the bearing either by tightening a nut until you feel resistance turning the wheel then you back it off just a touch or with sized spacers ( tedious ) or it wears prematurely. Old BMW motorcycles and Harleys had tapered rollers in their wheels. They have to be removed, cleaned, greased and pre-loaded at regular intervals. Same with many older cars and with the big tapered roller bearings on motorcycle steering heads. Get the head bearings pre loaded wrong and the bike handles really bad. I got good at it but don't miss messing with tapered roller wheel bearings. With ball bearings you seat them in the wheel or hub and slide slide the axle through. No pre-loading necessary.
I just gave you four sources from NSK, SKF, and NTN that say preload has uses for ball bearings lol. Are you saying they are wrong?
The Ametek diagram shows they consider the spring washer to be a load spring. The end play and vibration control you mention are results of the preload being applied.
Page 116 of this document talks about the use of spring (wave) washers to apply preload to reduce skidding and noise: https://cdn.skfmediahub.skf.com/api...edium/0901d1968024f02a_pdf_preview_medium.pdf
This document also describes their use: https://www.schaeffler.com/remoteme...loads_24/barden_ball_bearing_basics_us_en.pdf
made some research about legal actions, according to EU regulations on eco-design and safety (Regulation 666/2013), manufacturers must indicate the nominal power on the "plate" of the appliance or continuous power guaranteed by the battery rather than the maximum peak of the engine
The 450W label is used for safety and electrical compliance, while 900W is used to describe the maximum performance of the engine in marketing campaigns and official data sheets, adding that if Dyson wrote 900W on the technical label of a product that consumes an average of 450W, it would be sanctioned for providing a false data on
@Hatsuwr, the absolute TL;DR is that suction determines air speed, airflow is secondary to suction (pressure difference by the way), airwatts is like electronic circuitry (suction ≈ voltage, airflow ≈ amp current, flooring and leaks ≈ resistance), and you need both good seal and proper agitation and effective pile separation. The best cyclonic designs are far better than bags because they doesn't lose suction unless overfilled bin or reckless usage, and finally...
@Hatsuwr, my thoughts line up with @Vacuum Facts'. He is the most objective guy in vacuum cleaner reviews, but he is not perfect (he can be obtuse and kinda ungrateful, and forces us to understand instead of simply helping out). But you know...
Dyson motors are far too small for normal ball bearings of any reasonable size, by the way.
Interesting...
This is mainly demonstrated also by vorwerk who made a product with 700w label on but in boost mode the maximum power goes to 900w
It's not all that different from Dyson's machines, which in Boost mode (for cordless) generates more power than their respective motors are rated at. (Gen5 nearly 1,000W while rated 752W; V16 nearly 1,100W while rated 900W max)
Interesting...
We could definitely admit that this v16 is less powerful in eco and medium but more powerful in stress boost mode, then the previous gen5 mainly for battery’s preservation
I have never seen that kind of power consumption with the v16 - no matter which attachement or cleaning scenario and this 2x power consumption difference from the nominal rating given on the label would be pretty much out of line compared to the older machines.
The data was collected from all machines i have - tested with no attachement (what should give maximum motor power data)
V11 Outsize 91 wh battery size / runtime 8:06 --> 674,1 consumption / 545 nominal = factor 1,237
V12 63 wh / 5:35 -> 667 / 544 = factor 1,226
Mirco 1,5kg 36 wh 6:37 --> 326,45 / 225 = factor 1,451
Gen5 90wh / 5:35 -> 967,2 watt / 752 = factor 1,286
V16 99,97 wh / 11:30 --> 495 / 450 = factor 1,1
All machines had factory new batterys except for the micro (that i bought 2nd hand and i do not know how good the battery is so the data is maybe compromised by this) have around factor 1,25.
So the v16 would have the out of the line factor 2x or even more and i still have no data found that the 900w is actually no marketing term and actualy means 900 Watt which should give about 6:30 minuntes of runtime (or less if > 900 watt).
First Italian review of v16 demonstrated (in a very extremely way) how the new head it’s basically useless for his primary feature (detangling), my v15 with his normal direct drive head never never had problems with hairs too
    1.8 MB
    1.7 MB
So basically, did Dyson lie to everybody?
Oh btw are you the one from the YouTube channel? Welcome!
