Hoover Anniversary self-propelled windtunnel.
Question, does the Hoover Powerdrive work in both directions? If only forward do you shut it off to pull the vacuum backwards? Kind of curious how it works.
The upper handle moves about and pushes/pul,ls a cable. It can be turned off. It is in both directions. That reminds me of my first g series rebuild where I used a drill to tighten down the slide plate. It was stuck in forwards. Ran straight into the wall.
I have seen that rod for sale many times. So when you pull back on the handle it changes the direction of the Powerdrive to reverse? Slick.
Hopefully the grease will fix the gear slop, if that is the correct grease for this application, if its still a problem then I'd say the teeth got wore down and they aren't connecting right. Just have to try it and see. Someone probably used it a lot.
It was very used. Strange, because my 2001 Self-Propelled Windtunnel was also heavily used and the transmission sounds perfect in it.
