Any equivalent fan I could use?
royalfan103
Bremerton, Washington
So, my Shop Vac QSP Pro has had this awful vibrating sound during operation. I took it apart and no matter how much I tried, it still vibrated. There was nothing rubbing against the fan and the fan was balanced. Out of all the times I worked on it, the fan was different compared to the other fans I’ve worked with. Google’s AI told me that the fan was corroded and I’m wondering if I could replace the fan with something equivalent. I have a caliper and measuring tape I could measure it to so I could find a similar fan. The motor assemblies cost me $100 and I don’t have that type of money. What does this fan look like to you? The lower motor bearing was also bad and I replaced that.IMG_8498.jpeg
So, my Shop Vac QSP Pro has had this awful vibrating sound during operation. I took it apart and no matter how much I tried, it still vibrated. There was nothing rubbing against the fan and the fan was balanced. Out of all the times I worked on it, the fan was different compared to the other fans I’ve worked with. Google’s AI told me that the fan was corroded and I’m wondering if I could replace the fan with something equivalent. I have a caliper and measuring tape I could measure it to so I could find a similar fan. The motor assemblies cost me $100 and I don’t have that type of money. What does this fan look like to you? The lower motor bearing was also bad and I replaced that.View attachment 170751
What is the model number? With that you can search for parts schematics and part numbers here.
https://www.shopvac.com/collections...zITMWn_eMLHHrbaokzE-G4N6LHPcT2kDF5hhe1M-DGno8
What exactly is the issue with the fan? It looks structurally sound from the picture you provided.
Vibrations caused by the fan would be because the fan is unbalanced, which based on your picture would mean that either one of the impellers inside has become at least partially detached and either displaced or lost, or (and more likely in my opinion) there is significant debris stuck inside the fan.
If the fan is complete and intact, I would see if you can (briefly) run the vacuum without the fan installed to see if the vibration is still present.
QPL45a. Unfortunately, they don’t sell the fan separately.
Wow. No parts at all for the power assembly. Not even a replacement switch or cord. No good ! On our RIgid shop vac the fan is a separate part you can buy.
Do you know who makes the motor the fan came from? Probably not Ametek but you never know. Ametek manufactures in China for many Chinese made vacuums including Hoover and Pro Team. If you can find a model number off the motor sometimes you can get replacement parts from the motor manufacturer. Ametek is really good this way.
Sometimes you can acid dip corroded parts and clean them up.
Heavily corroded looking. I have some progress pics of the fan after cleaning with a green scrub pad, yes, this is dirt inside the splines, it looks very stubborn.
Maybe soak in in vinegar than put a hairdryer in the centre to push the air out. Or something like an Electrolux or a Kirby on blower mode. Also before soaking it try to cusk the dirt out of the vanes with a strong vacuum, also I mean strong hose suction not strong carpet performance.
It’s soaking in some vinegar. Should I leave it for a few hours?
I wouldn't. Vinegar will corrode the metal. If heavy corrosion buildup is your concern, there are better ways to remove it that will do less damage to the part. Otherwise just clean it with a good detergent. Could also use an ultrasonic cleaner if you have one.
I did find this sticker on another shop vac I parted out. Still no identification on what company makes these motors.IMG_9032.jpeg
I did find this sticker on another shop vac I parted out. Still no identification on what company makes these motors.View attachment 171039
The UL numbers show Shop-Vac as the maker so I think they make their own motors, or this one was.
E179834 is the UL certification code
FMC-01/FMC-02 is the model number.
The F circled to the right of the UL code shows its the FMC-02 motor, if A was circled that would make it a FMC-01 motor.
