Dyson dc07
SeboU1
Gold Member
Pittsburgh PA
Well I’m not really a Dyson fan, but I absolutely love the quirks of the dc07. I just bought one at a good price in descent condition. I am going to automatically replace the filters, any other suggestions? I was going to order the clutch but I think I’ll see if it needs one. The dc07 seems to be one of Dyson’s most reliable designs, does anyone know what motor they used, it seems like they used a quality one?
Good machines but be very gentle as the plastic is very brittle on those older Dysons now. At least the US ones.
I'd check the internal hose, I've seen those commonly tear out (I even had to replace mine as well). These used two different types of motors here in the US, the most common one is Panasonic and the one I don't see too often is YDK.
Once I saw one at a pawn shop with the following problems: bad belt, bad brushroll, worn out soleplate, split main and lower hose, bad bearings, bad filters, a missing u tube and it had been used on water. Apparently they paid $60 for it, they wanted $150.
Well I’ll make a condensed comment on all your replies. I never would have thought that they have a Panasonic motor, they’ve proven reliable. I purchased it from eBay for $65, and told the seller to pack very well, as they can be brittle. I examined the pictures carefully, my uncle still uses one, and I knew what it should have. I was definitely not going to pay over $200 for the others on eBay. I did prefer the lower hose, as it affects the contact with the floor. I was going to buy the clutch and brush roll, but I’ll see if it needs it. The main hose can easily be sourced. I’m also covered on base blades, eBay has several for sale. I just hope it arrives in one piece, I’ve been lucky so far, we’ll just see. I absolutely love the quirky sound that the cyclones make on the dc07, it finishes a strange but good looking vacuum off. My grandmother’s stowaway motor head had an electrical problem (8 years ago) and my uncle brought over his dc07. I cleaned all three thousand square feet with that dc07 and really liked it. My uncle’s dc07 is from 2004 and I guarantee it never got serviced, it’s still running strong.
From what I have seen a lot of 120 volt Dysons have Panasonic motors and 240 volt Dysons have YDK motors. Not 100% but that is the trend.
That’s a great score! The Dyson DC07 was kind of a benchmark back in the day built like a tank and surprisingly easy to keep going. If it’s still humming along, you’re probably fine with just swapping out the filters and checking the seals. In our workshop experience, clearing out the airflow path actually tends to have a bigger impact than messing with the clutch. Little things like keeping the brush bar clean and making sure gaskets aren’t clogged can quietly add years to the motor. Funny how, when tuned right, these older models can still outshine some of the newer ones. Just goes to show how much proper upkeep really matters.
The older Dyson are also easier to work on! I had the pleasure of working on a dc40, the wire that gives power to the motor head broke. That model never went back together very well, and the replacement wire only lasted 6 months.
I have seen countless machines ruined by poor maintanence. Big, bright and bold stickers are needed in my opinion.
All the bright stickers in the world won't fix the problem. I have occasionally quizzed people shopping for a new vacuum at Wally World asking what was wrong with theirs. The typical answer is "the brush stopped turning". I then ask if they checked the belt to see if it was maybe broken. And the answer nine times out of ten is "oh, I don't have time for that, I need a vacuum right now". Doesn't help that Wally World has no spare belts. So the fool parts with a Franklin for a new pos bagless plastivac when all their existing pos bagless plastivac probably needs a new belt.
