I may just do that at some point. But I can tell you now, if I have to plug it in, if it's heavy and mains upright formfactor, if it requires more than a couple of hundred Watts for nominal cleaning, if it has continuous power level and not dynamic based on dust loading, if it has anciliaries and running costs, if it's noisy, if it doesn't have anti hair wrap fully solved, if above floor and stairs cleaning is a pain and not instant, if it uses belts, if it doesn't highlight dust on hard floors, if it doesn't work automatically across all floors without any user intervention, if it has fiddly dials to adjust head height, if it has two fixed wheels that impair manoeuvrability, if it doesn't show me how full the dust receptacle is, if it doesn't sweep hard floors of fine dust, if suction reduces as a function of dust loading, if I can't just buy it online direct from the manufacturer in my local region and get next day delivery, if I don't have a 35 day return without condition, if it snowploughs, and if it only can manage 99.97% filtration of particles greater than 0.3 µm, then this is not good enough for today's technology and it will be heavily criticised, since we've moved on and solved all this. YOU need to try better technology, understand, and appreciate it at a deeper level before passing judgements about those that write off old crap that may still clean well at a price.
People that thought they knew better said the exact same thing for the sebo felix. It was totally insufficient. It cleaned great, but talk about consequences that I've no time for in a better world.
