Hoover Convertible U4309
Wheatland, CA
After sitting in my closet in pieces, I finally put it back together, put a brushroll and belt into it switched on and man the growl on this thing is amazing. It did have a slight problem with the washer that went behind the motor pulley I took it out and that fixed the problem.
    2 MB
    1.1 MB
    1.2 MB
    1.1 MB
    1.2 MB
    1.2 MB
SPENCER the hoover convertible u4309 was famous for being the first plastic based full hooded ( concave shaped hood with colored bumper ) upright with headlight introduced in 1980 in the new u43...... series convertibles. it was a promotional model featuring the 5pc tool kit packed into the unit and was a huge model for macy's abraham and strauss and gimbels for it was heavily featured in their advertising ....i live in scranton pa and it was sold heavily at the sugermans department store in eynon....it featured the high performance 2 speed motor and the 12 blade scoop fan which gave it unbelievable suction power yet still using the bottom fill bags....it also introduced the vertical abstract multi colored design bag pattern to the hoover convertible line up .i still have my grandmothers in my store collection you can see it at sweepercentral.com.....
Did the U4309 use a plastic 12 blade fan or aluminum fan? I'm asking because it came with an aluminum fan
SPENCER the u4309 would have come with the 12 blade first edition black plastic fan with the swirl scoop blades part number 38755-001 which made incredible suction but were more prone to rupture ....your u4309 had this 12 blade black plastic fan that had broken. most vac shops would replace it with the original pt number 22556 metal hoover convertible fan
