atrac
...or is it?
I found a Dyson DC14 a few months ago for $10 at a local thrift. When I tried it out I heard the ratchet noise. Also noticed the hose was torn near the top (the part that goes into the handle).
I finally borrowed a pair of wire cutters this evening and managed to cut away the bad part of the hose and re-glue the remaining good part back into the rubber/plastic attachment end. Problem fixed -- it's just a little shorter now, but still more than usable!
But that ratchet sound. I've read and assume that it is indeed a bad clutch. I've watched the video on how to repair it. Seems simple enough. What I am wondering is if that noise instantly means "replace the clutch" or is it just possible the belt is slipping? The brush roll still turns -- there's just that loud clicking sound when I engage it. Can you even open the clutch to replace the belt?
Obviously I'm trying to keep the cost down on this (which so far is insanely cheap). But if a new clutch is the best solution, I'll take it.
Thanks!
Thanks!
