kirbyman65
I’m curious what everyone thinks is the worst out of these. I don’t think every vacuum on this list is bad, I just want to give people lots of options.
A properly designed HEPA filter is not restrictive. The US HEPA standard specifies a maximum allowable reduction in airflow in addition to the high particle capture number. I have tested quite a few vacuums with both paper and synthetic HEPA dust bags and the paper bags are more restrictive than the synthetic bags. I have not seen a HEPA filter reduce airflow measurably.I pretty much agree with that rlsellman21. I don't think a machine has to be whole machine HEPA sealed as long as it has a good bag. The Tellus gm90 for instance, it had 4 filters. They were the bag, then the XXL thick cotton filter, very fine cotton or polyester filter before finally going through an electrostatic filter. That way there is no restrictive HEPA filter but all the dust is caught somewhere in the system.
That is not true. They don't clog faster. The very spec these filters have to meet in order to qualify for the US DoE HEPA standard ( US DoE STD 3020 ) requires the filter to be able to trap 99.97% of particles .3 microns in size with a maximum allowable resistance of 1.0 to 1.3 inches of water gauge depending on the size of the filter. The US HEPA standard requires the filter to flow air even when it has particles entrained. That standard has its roots in the Manhattan Project where filters were designed for air handling equipment in facilities handling nuclear materials. The 0.3 micron specification corresponds to the size of specific nuclear particles the Army wanted removed from the air. The spec requires the filters to continue to flow air when contaminated.I mean that a HEPA filter clogs and restricts airflow quicker. I understand that is because they are capturing more dust but they have the heat build up behind them and burn out the motor. I have seen about 5 different machines that were all less than 10 years old that had been put to waste because the HEPA filter had bent and literally burst.
The US DoE HEPA standard is the one used by many US vacuums. Many vacuums that use filter media rated to the US DoE HEPA standard say "True HEPA". Kenmore filters and bags specify they filter 99.97% of particles 0.3 microns in size. Hoover HEPA dust bags likewise meet the US DoE HEPA standard. Miele uses a slightly less strict European standard called H13 as do many other European vacuums.I agree about Dyson and riccar. Vacuum manufacturers really won't be bothered to follow nuclear industries guidelines. Also, they are filtering out very fine dust while vacuums have larger dust too. I have seen piles of modern s-filter Electrolux machines stop working because they have clogged up the exhaust HEPA filter so much that the frame has melted and bent then holes gets punched in the HEPA media. This happens withe Miele's filter system too.
Filter media that can trap 99.97% of particles 0.3 microns in size capture 100% of larger and smaller particles.I understand that it's just that the particle size a HEPA filter is designed for and what it is needed for in a vacuum are 2 very different things.
