kirbysthebest
Sock
Depends on the mode you are in.
If in upright mode, then more than likely you will jam the brushroll and slip the belt. In canister mode depending on the size of the sock you could stop the hose, or if it make it to the fan will more than likely be stopped by the shaft.
