sptyks
I did some research on this and what I found is very interesting.
The fans that are installed in the newest Kirby's from the G5 through Sentria II are made of Amodel, NOT Kevlar as almost everyone on here has thought.
For a while Kirby used Lexan, which was discontinued when the switch to superior Amodel was made in the G5. Amodel is widely used in the Aerospace industry so Kirby designed the new fan with the aid of NASA so that it would be the most durable and produce maximum airflow(CFM).Many folks on here, confused Lexan and Kevlar with Amodel. There were some problems with the Lexan fans after a few years of use. They would suffer stress fractures and would break apart if hit by any foreign object (not regular dirt).
Amodel is a new type of polymer that is several times stronger than either Aluminum, which is used in the Royal metal upright vacuums, or Kevlar which was NEVER used in any Kirby vacuum. The Amodel fan is tougher than metal and believe it or not, will almost always outlast Lexan and metal fans.
A few years ago, Kirby did a demonstration for some VCCC members during a tour of the factory where they used a Kirby vacuum with Amodel fan to suck up a bowlful of large nuts, bolts, marbles and pebbles. After disassembly, the fan had only a couple of very small nicks on it and deemed fully serviceable.
The Kirby Sentria with it's higher speed motor, and NASA designed Amodel fan, produces more airflow (115 CFM) than any previous Kirby model.
Here is a statement by Solvay Advanced Polymers which is the manufacturer of AMODEL polymers. You can find this statement on their website with the link provided below:
" About AMODEL Polyphthalamide--
With a heat deflection temperature of 536 degrees Fahrenheit (280 degrees
Celsius) and continuous use temperature of 338 degrees Fahrenheit (170 degrees
Celsius), AMODEL PPA retains its exceptional mechanical properties --
strength, stiffness, fatigue and creep resistance -- over a broad range and in
high humidity environments. This versatile family of high-temperature nylons
can give you the strength of aluminum, the stiffness of steel, and the impact
and ductility of hard rubber --"
I hope you all enjoyed the fruits of my research of AMODEL and look forward to reading comments any of you may have.
-Stan
[this post was last edited: 12/23/2013-22:04]
http://www.prnewswire.com/news-rele...anufacturer-pump-up-performance-54224587.html
-Stan
