Which vacuum stands the test of time?
CTV...
The Eureka Boss NEVER picked up the dog hair! I was embarrassed last fall when I had my carpets professionally shampooed!
Lori Ann
Gotcha. Simplicity canisters are great, it boils down to how many features you want. Like you said I like having controls on the handle.
Stan...
Thank you! I almost bought the sentria, but with my allergies I'm thinking that the dust in those is not so good for me!????
I have Kirby, Electrolux and Rexair / Rainbow. My 1949 Kirby will still outclean my Electrolux on carpet but my Electrolux will outclean my Kirby above the floor. Rainbow is great if you have allergies but you have to clean it up after every use, you can't just put it away wet.
Kirby's will last a lifetime if you take care of them. The older metal body Electrolux will also last a long time, the new plastic body will last a long time if the unit isn't dropped and the body cracked. I also have Rexairs from the '30's and '40's that still work wonderfully well and have already lasted a lifetime.
Well for starters I don't spend much more than $15 to $20.00 on a used vacuum from say the thrift shop, garage sale or where ever. Secondly I'am very fluent in taking stuff apart and doing the reapirs and checking over the whole machine.
I have an older Panasonic McV5218 Upright or something like that. It is on its last legs now, but it has proved itself a very fine machine for over 12 years.
I prefer Bagged machines, never will buy a Bagless, the dust bin can build up with bacteria after a while and emptying it is a nuisance and the hepa filters need frequent changing.
Having said that Ricaar and Simplicity are very good Vacuums. I would not buy a miele they tend to have some quirks that can and will eventually haunt you returning to the vacuum shop for costly repairs.
Buy an Uprite with a Floor/Carpet selector on the power nozzle, that way you can also drag it outside to clean the car without the power brush churning away.
Its also a bonus to buy a machine with a metal brush roll as these have removable brush strips which are cheaper to replace than the whole brush roll. And do maintenance on the Brush roll portion of the machine every 6 to 12 months depending on how much you use it. And keep the motor pre-filter clean, this will increase the longevity of the motor. Its always better to change bags when 80% full so as not to cause over heating.
A quality machine if looked after will last over 20-30 years. Thats my 2 cents.
It is!
The canister I can get is an S36 for 300 (refurbished, only needs new hose)>..
can anyone affirm if this is a decent machine?
The S36 is a very old machine. At least five years if not more. Good vacuum, but you have to drag a canister behind you.
hhhmn
So a 5 or 6 yr old S36 for 300, is that a good deal?
Or should I spend a little more and buy the Deluxe model?
Or should I go Kirby?
I would go for the Kirby Sentria out of those choices- It is the most versatile, and will last a lifetime (or several!) if you maintain it. You can buy high-filtration HEPA bags for it, and although the bags are a bit pricy, they hold a lot of dirt. It should be great on pet hair, you can even get a pet owner's brushroll with stiffer bristles. If, and I'm saying *IF* you should ever damage the fan (not likely), it is a fairly inexpensive repair.
You can never go wrong with a Kirby! They are proven to stand the test of time and have a wonderful life time rebuild as well.
I am not a fan of any of the new uprights with onboard tools. Stretch hoses, the cheap tools, along with the added weight to the machine make it clumsy and awkward to use. Most of the clean air uprights draw suction or use a hose to one side of the machine. This reduces the air flow at the opposite side of the machine. Edge cleaning is weak on these machines.
Since a Kirby is a direct air machine and draws air from the center, edge cleaning and over all air flow is much better.
The other factor is that a Kirby is only around a 6 amp machine. Kirby has received awards for being an Eco Friendly product. Almost all of the materials in the machine are recyclable and can be repaired.
Some will claim the air flow for attachment usage is weak compared to a 12 amp machine, I don't find any truth to that. I have always felt that a Kirby is a great deep cleaning work horse that lasts for years.
Just my two cents... Royal metal uprights are also a good choice. (tool usage not as easy)
I've put feelers out for two local Sentries. One she said her mother inlaw bought used once and said is too heavy... the other they have two units... the second is hundred cheaper (350 & 250)... both look brand new in pics supplied!
Both just responded to my texts... making plans to pick one up. Not sure yet which, as the first mentioned is willing to negotiate and is closer.
Yes, You should be excited! That sounds like a great deal if it is in good condition. Maybe post pics after you get it, and definitely let us know how you like it.
another decision
OK, so I can obtain a Sentria that is approx. 6 or 7 yrs old (probably refurbished, as it is a guy who sells Kirby's) for $200....
Or, I can obtain a Sentria that was purchased late last fall for (listed at $350).. this one I have a feeling is Sentri II and she has OBO on price.
I'm going to see if my son wants one, that will solve it... but if he doesn't, is it worth more for the newer model? I'm unfamiliar with the differences.
thank you all!
Lori
That's a super low price for a new condition Sentria. Does that price include all the attachments? If it does, then you should congratulate yourself on a fantastic deal! Let us know how you made out, and if there's any questions you have about the machine or its use, besure to let us know.
