whatisthis
- Joined
- Apr 7, 2012
- Messages
- 5
hi, i was handed this bad-boy and asked 'fix it?'. so i'm new to vacuum cleaners, but i've worked on nearly everything from edison machines to weapons carriers and everything in between. apparently vacuum cleaners don't have a serial number and model number on the data plate. this one doesn't even have a data plate at all!
at first i thought it was sputnik fallen to earth but it's a eureka, front says roto matic. the aluminum hose intake at top swivels. it has wheels but they are two separate assemblies and not in this photo. it has a cloth filter bag (that has holes) with a molded-in round rubber gasket. it 'had' (keyword is 'had') a filter band around the fan motor vents that looked like it was made of raw fiberglass or some other nasty material, so that got thrown away in half a heartbeat.
it is deceptively heavy for it's small size... if i drop it, it may crack the tectonic plate or even knock the earth out of orbit.
1) does anyone know exactly what model this is?
2) are replacement cloth bags available?
3) better then cloth, are paper bags available?
4) is a replacement filter band for the fan motor available?
many thanks!
ps. i was told that until recently it had been used as a leaf blower. no, really!
many thanks!
