What Do I Have?
abobotek
Redmond, WA
I have a new Electrolux 2nd-hand store find and am wondering what it is. Clearly the base vacuum is an Electrolux Automatic F. But what about the cord winder? From the color mismatch, it does not seem to be a part of the original vacuum.
Questions:
1. Is this a cord winder that was installed afterwards or from a different Electrolux model? Are the hose and cord original?
2. The floor/carpet brush is stuck onto a wand and I cannot remove it. Pushing the release lever and twisting with all my strength doesn't separate them. Any suggestions on how to get them apart or are they now permanently attached?
Thanks!
Vacerator - That is NOT a Hospital G! Clearly, as the poster says, it is a Automatic F with some upgrades.
Abobotek - Those parts are definitely replacement parts. Since your flip over floor tool does not match, I would suspect that someone scrapped a Automatic E and added the floor tool and cord rewinder to improve the vacuum.
One of the advantages of Electrolux is that many parts, attachments and bags can work with several models. The upholstery nozzle is from XXX or LX,cordwinder is from AE, floor nozzle from Mo G, crevice tool and hose are generic but should work well. For stuck nozzle stand wand up and use WD-40 or similar,let sit, come back later and twist or tap gently. Are you familiar with the rug/floor nozzle and dusting brush each having 2 sides?
You may be able to free the floor tool from the wand by running the hottest water your faucet has over the connection until everything is good and hot,or pour boiling water on it at the connection. Sometimes getting things hot can get them to loosen up. Not 100% but works often enough to be worth a try.
If that fails maybe try some Liquid Wrench or similar penetrating oil.
Thank you for the detailed information, rugsucker. It seems that I have a quiet, well-functioning high-quality Frankenvac rather than a collector's piece. While I expected high quality based on the use of metal and overall build quality, the low noise and good suction were a pleasant surprise!
Thanks for the tips, cheesewonton. I had tried using a heat gun, first removing the vinyl from the locking tab. It got over the boiling point of water and I still couldn't twist it using a strap wrench on the wand. Penetrating oil is next! Or I could just leave it; with 4 wand sections, having one permanently on the floor tool is juat an inconveniece and this mish-mash of parts from different models is nor a collector piece.
Heat guns are kind of wimpy. I have never been too happy with their ability to heat things up well. Try running full hot tap water across it for a couple of minutes. Hot water seems to heat things better. With the heat gun you can be heating one side up but the other side is cooling down. With hot water you get the heat all around. If that fails then try penetrating oil.
Yes, I would agree with using a penetrating lubricant as your next step. And whether you use WD-40, Liquid Wrench, Blaster, or another type, be sure to give it some time to soak in before you attempt to dislodge it. You might want to spray it and wait at least twice before you attempt removal. Hopeful this will work for you.
However, if all else fails, as a LAST RESORT, you could use 2 pairs of Vise Grips. Put one on the wand and one on the swivel collar of the nozzle, tighten both just enough to grip without slipping, then turn both in opposite directions. This method should ONLY be used as a LAST RESORT, because it will leave marks on the wand and/or nozzle. Hope this helps.
