Watermatic/Filter magic motors
blackheart
North Dakota
So i picked up a 2008 edition Filter magic a while back and just yesterday i opened it up to see what kind of motor it had and discovered it had a flow-through. Due to their ability to pick up water i assumed, similar to the fairfax and silver king, that they used a Peripheral bypass.
So now i'm curious do the older models also use a flow through motor?
Okay
Thanks for the info Hans. Are they a pretty long lived vacuum or do they tend to have shorter lives? I was never too worried about it when i thought it had a bypass but now that i'm aware of the flow through motor i'm a little paranoid about keeping it cleaned out so it doesn't overheat.
Dont worry
About all older machines use a flo thru motor, They are pretty much eternal unless you really abuse them, Remember all Electroluxes, Eurekas Hoovers and Compacts as well as many others used flo thru motors.
Usually flow through motors don't bother me but with it using flat filters with so little surface area= 78.5, for comparison the tristar's bag is about 250 and moves a lot more air than the Filter magic does. So i guess my worries were just due to that. However, i will trust your experience(s) with them, and not worry about it. i do enjoy a decent "tub style" vacuum.
