Washing Machine Woes
bagintheback
Flagstaff, Arizona
I'm wondering if any of you guys could provide un-biased advice on my General Electric washing machine. I have nothing but conflicting information between GE and the contracted reapir man, and would like to know what is truly going on.
In October 2012, my family bought this machine through Home Depot along with a gas dryer. The washer is pretty low end, but all the controls are set by an electronic dial; nothing is mechanical. We were experiencing great performance until about late February, where durring heavy loads the drum would spin off balance. Aware that is a normal occurrence, we would rearrange the clothes, yet this had little impact. It did not bother us much, but the problem got progressively worse, to where multiple rearrangements were necessary just to get to the rinse. We began to cut down our load sizes, but no matter how little material was inside, the drum would clang and clang endlessly. The drum is easily moved by hand; almost no force is necessary.
So I finally call GE and am sent to an automatized warranty service number. GE has contracted a local repair company to deal with warranty reapairs, so the person working on the machine has little direct relation to GE.  They came out last Monday, with the diagnosis that we need a new balance ring, which he would order, and that we can continue to use the washer safely with extremely small loads. So that's what we did. A day later, rattling is heard from below the drum and now the motor can not turn the drum all.
Thursday we call the repair people and they say the part should be here Friday or Monday. Today we receive a call from them to tell us the part is on backorder. To get some action going, I call up GE directly and explain the problem.  I give them the model number, let them know we need a balance ring, and am told, to my surprise, that the part is available. Not only is it available, GE provides next day shipping to any service provider in the country.
What is going on here? How can the repair company expect us to wait a week for a part, when they can get it the next day, and then tell us it is on backorder, when GE directly tells me it's available. Who else could they be ordering from if they work for GE? I don't know what to think at this point. I don't want to accuse anyone of lying, but something is obviously wrong, and we need a washing machine.
Any ideas?
Can't GE fix your machine under warranty?If you are unhappy with the machine see if a refund is possible.Then go to a "swap shop" or thrift store and buy a vintage machine-those are much better than the junk being made now.A vintage GE washer would be an improvement,and cheaper,too!
Nathaniel I would just call the service company and explain to them what GE said and see what they have to say for themselves.
The balance ring could be the culprit if it has leaked out its liquid or a loose or broken shock absorber or its linkage could also be the problem.
This sort of thing can happen when a service provider has a contract with a specific parts supplier. The part may indeed be available from GE overnight. But your repairman has placed the order through his parts supplier, and his supplier doesn't have the part in stock. So his plan is to sit there and wait for the part to come in through his normal supplier. If it was me, I'd tell that service tech he had twenty four hours to fix that machine or don't bother coming back. Service providers are supposed to be in the business of providing service, not excuses, so don't let him make any. It would be different if the part really wasn't available, but that isn't the case here.
Is this a front-loader?
Your symptoms sound very similar to the ones I was experiencing last year. Front-load washer (don't recall the brand, might actually be a GE) from 2006 but only has the equivalent of a few months' worth of use (second home). It was doing just what yours is; shutting off as if from an unbalanced load, and making lots of banging noise on the spin cycle. I took it apart to find both shock absorbers broken. Extremely weak plastic where the shocks are pinned/bolted to the washer body and drum. The replacements that I bought seemed to have an improved design.
Very surprised that an appliance tech didn't catch this on yours, though. Might be something different. Just a suggestion. It was only a couple of screws to take the front off and take a look.
An Update
The repair man just left. Apparently, the drum flew so off balance a bracket snapped off, hit the motor, and has now completely failed. A new motor will have to be ordered, which is a frequent problem with these GEs.  Nothing but complainants on this model from the repair man.
You can be sure we will never purchase a Genreal Electric product again. Well, off to the laundromat! At least there they use Maytags!
NEVER Buy a General-Electric product again!?
Not even one with <span style="text-decoration: underline;">Reach-Easy cleaning?</span>
<span style="color: #000000;">:P</span>
<span style="color: #000000;">-Alex.
</span>
