I cleaned up the coil and worked on the commutator. I was able to use a strip of 600 grit sand paper to smooth it out and remove the raised ridge, then used a razor knife to undercut the mica. Overall I think it cleaned up pretty well. Once I’m confident that it’s had enough time to dry out I will hit the windings with some clear varnish. The coil had an unbelievable amount of grease built up on it.
Here are a couple before shots:[this post was last edited: 8/14/2023-19:29]
