vacman1961
I was over fellow member Chuck Chatham's vacuum store this past weekend and a customer had dropped off a very odd vacuum. It is called the Defender, it was manufactured in 2007 by Defender Vacuums in St. Johnsbury, Vermont. The thing that makes this vacuum odd is that it is made out of PVC plumbing pipe. It is 5" in diameter and it has a Lamb 2 stage double ball bearing motor in it, as you can see the construction is very crude, you can almost tell that the person who designed it know very little about vacuum cleaners. The bag system seems to be all Airway, from the inner filter to the paper bag. The hose is permanently attached to the front cover, so if you want to remove the hose, you leave the dirty bag exposed. It has a generic electric hose on it, and according to Chuck it sounds like the description of the power head that the customer described it is a Douglas. I tool some pictures, I hope I can get them to post.
