beko1987
Amys dad mentione the last time we were up that they were after a vacuum cleaner.
I found them one!
From Vax Centrix 3
Looks like a Hitachi to me! Still, its not too horrendous, certainly got some airflow going. However, it had been used for DIY
From Vax Centrix 3
From Vax Centrix 3
From 2011, so obselete by Vax's standards!
Let's go then!
From Vax Centrix 3
Bottom flap flaps down by a very crude clip
From Vax Centrix 3
From Vax Centrix 3
"HEPA"* filter
From Vax Centrix 3
From Vax Centrix 3
From Vax Centrix 3
From Vax Centrix 3
I vowed never to touch another new vax again after the Turboforce fiasco!
From Vax Centrix 3
The plunger is plunged with the filter inserted. No idea what it actually achieves though!
From Vax Centrix 3
Mmmm grimey
From Vax Centrix 3
From Vax Centrix 3
Cyclone* shroud
From Vax Centrix 3
From Vax Centrix 3
From Vax Centrix 3
And that was the dirt bin fully stripped.
Seller said it had been lightly used. As soon as she said that, I knew she was a lying toerag and this thread and its contents would happen...
After undoing lots of screws Ilifted the motor cover
From Vax Centrix 3
From Vax Centrix 3
From Vax Centrix 3
It's intended owners have already done their DIY, and this will be lightly used so hopefully it wont look like that again...
Eventually found this screw hidden behind a wheel, which I had to pop off very awquardly
From Vax Centrix 3
From Vax Centrix 3
From Vax Centrix 3
From Vax Centrix 3
I wouldn't undo those 2 screws if someone paid me to!
The cord exit has rollers top and bottom, which I find quite nice
From Vax Centrix 3
From Vax Centrix 3
From Vax Centrix 3
From Vax Centrix 3
From Vax Centrix 3
Ah, we must be nearly there then...
From Vax Centrix 3
For some reason, the blockage sensor tube was fitted with a kink in. Will be shortening it to take that out before re-fitting it...
From Vax Centrix 3
Oh look Numatic, a huge heatsink to keep the triad cool and stop it from blowing.......
From Vax Centrix 3
From Vax Centrix 3
Extracted the throbbing beast
From Vax Centrix 3
From Vax Centrix 3
From Vax Centrix 3
From Vax Centrix 3
From Vax Centrix 3
The loud (but not screaming loud) motor
From Vax Centrix 3
From Vax Centrix 3
One of these is 1200w, the other is 2000w...
From Vax Centrix 3
From Vax Centrix 3
Oh god make it stop!
From Vax Centrix 3
From Vax Centrix 3
From Vax Centrix 3
From Vax Centrix 3
From Vax Centrix 3
From Vax Centrix 3
From Vax Centrix 3
Done! with the main body at least! Fair play vax, everything just screws together. Turboforce was very similar. Makes cleaning very easy
Floorbrush now, although it's an odd one as it doesn't fit the parking slot. Something obviously did, as there's wear marks on it where one has been parked before.
Anyway, it's all academic really as it's very very broken. The lady had heard of me as she said "You sell Hoovers dont you?". I said yes, and proceeded to get it all out and inspect. Got some money off for this. She was genuinly surprised at the state of it tbh
From Vax Centrix 3
From Vax Centrix 3
From Vax Centrix 3
From Vax Centrix 3
From Vax Centrix 3
It all went in the bin, and I got this nice one out of my spares pile. Will be better for amys dad anyway, they have mostly laminate,with some deep but very flat carpet (going to take a turbopower with me the next time we visit!)
From Vax Centrix 3
However it also needed work
From Vax Centrix 3
From Vax Centrix 3
Found a motor sticker
From Vax Centrix 3
and took the hose ends off
From Vax Centrix 3
From Vax Centrix 3
Lots of very small fiddly screws!
Currently waiting to be washed, I put the Dolphin back together afterwards!
More soon!
I found them one!
From Vax Centrix 3Looks like a Hitachi to me! Still, its not too horrendous, certainly got some airflow going. However, it had been used for DIY
From Vax Centrix 3
From Vax Centrix 3From 2011, so obselete by Vax's standards!
Let's go then!
From Vax Centrix 3Bottom flap flaps down by a very crude clip
From Vax Centrix 3
From Vax Centrix 3"HEPA"* filter
From Vax Centrix 3
From Vax Centrix 3
From Vax Centrix 3
From Vax Centrix 3I vowed never to touch another new vax again after the Turboforce fiasco!
From Vax Centrix 3The plunger is plunged with the filter inserted. No idea what it actually achieves though!
From Vax Centrix 3Mmmm grimey
From Vax Centrix 3
From Vax Centrix 3Cyclone* shroud
From Vax Centrix 3
From Vax Centrix 3
From Vax Centrix 3And that was the dirt bin fully stripped.
From Vax Centrix 3
From Vax Centrix 3
From Vax Centrix 3It's intended owners have already done their DIY, and this will be lightly used so hopefully it wont look like that again...
From Vax Centrix 3
From Vax Centrix 3
From Vax Centrix 3
From Vax Centrix 3I wouldn't undo those 2 screws if someone paid me to!
From Vax Centrix 3
From Vax Centrix 3
From Vax Centrix 3
From Vax Centrix 3
From Vax Centrix 3Ah, we must be nearly there then...
From Vax Centrix 3For some reason, the blockage sensor tube was fitted with a kink in. Will be shortening it to take that out before re-fitting it...
From Vax Centrix 3Oh look Numatic, a huge heatsink to keep the triad cool and stop it from blowing.......
From Vax Centrix 3
From Vax Centrix 3Extracted the throbbing beast
From Vax Centrix 3
From Vax Centrix 3
From Vax Centrix 3
From Vax Centrix 3
From Vax Centrix 3The loud (but not screaming loud) motor
From Vax Centrix 3
From Vax Centrix 3One of these is 1200w, the other is 2000w...
From Vax Centrix 3
From Vax Centrix 3Oh god make it stop!
From Vax Centrix 3
From Vax Centrix 3
From Vax Centrix 3
From Vax Centrix 3
From Vax Centrix 3
From Vax Centrix 3
From Vax Centrix 3Done! with the main body at least! Fair play vax, everything just screws together. Turboforce was very similar. Makes cleaning very easy
From Vax Centrix 3
From Vax Centrix 3
From Vax Centrix 3
From Vax Centrix 3
From Vax Centrix 3It all went in the bin, and I got this nice one out of my spares pile. Will be better for amys dad anyway, they have mostly laminate,with some deep but very flat carpet (going to take a turbopower with me the next time we visit!)
From Vax Centrix 3However it also needed work
From Vax Centrix 3
From Vax Centrix 3Found a motor sticker
From Vax Centrix 3and took the hose ends off
From Vax Centrix 3
From Vax Centrix 3Lots of very small fiddly screws!
More soon!
