Vax 121 Help!
tomvacuum10
Northern Ireland
Hi I was wondering if anyone has a photo of the solution control switch on a Vax 121. I was given one yesterday with only the large shampooing head used, but I don't know how to fix the solution switch. Also, is there a suppressor that would need taken out? I haven't had many older vacuums and I don't want it blowing up on me. Sorry about the bad photo.
Numaticrule29
Thanks for the info. Could you possibly send me a photo of what it is meant to look like? Also, is it easy to remove the suppressor? Thanks.
The solution switch has broken in half. It should be one piece.
Also, I really do not understand this obsession amongst some of the people on here of removing the suppressors from vacuum cleaners. The suppressor is essentially a capacitor and these are in so many appliances that unless you removed them all you are fighting a losing battle. Only the occasional suppressor blows - you hear about it on here sometimes as it makes for something to talk about. On a wet & dry cleaner like this Vax -where water can get into the motor and other parts- I would be much more worried about removing a suppressor and joining the cables together than I would leaving it in, as you can't be sure that water won't get into the join you make.
Vintagerepairer
Thanks for the comment. The previous owners must of used it a few times to shampoo their carpet as the dry tools were unused as well as the small shampoo head, and the main shampoo head was very clean. I think I'm giving it to a family member so I don't want it to blow up. Lol :)
As I said, the "blowing up" of suppressors is not a daily occurrence. You hear more of it on here than in the street as it is a forum for people who collect appliances where this can happen. What no one ever makes reference to is the safety and standard of the removal off the suppressor - only recently did I see a picture of a Hoover junior where this had taken place and the leads which were left dangling in mid air were trapped around a wheel in one instance. There is far greater risk of harm through mechanical damage there than there ever was from the off chance of a suppressor going bang. Don't believe all that you read on the internet.
