vintagerepairer
Yes that is exactly it. Because there is a small shampoo hose running inside the suction hose, the hose is designed so that it cannot turn through 360 degrees. You get to about 359 degrees (a guess but it must be about that) and a plastic moulding inside the handle prevents the hose turning any more. The user has to then turn the hose back. The machine end of the hose was worse still, because as well as only going about 359 degrees, the hose fitting has to be screwed onto the cleaner like a Numatic does. So, without complete freedom to twist round the hose, when attaching the hose to the cleaner, the hose fitting locks at say 359 degrees and then the hose starts turning round too. I must stress that this was on the models with the fixed carry handles, the type which came after the cleaner shown in the photograph above. As you can see there, the shampoo hose on that cleaner is very similar to the Vax and clips to the outside of the suction hose.
