Vacuum vibration
The motor itself blow out with compressed air. The fan blades... well it depends how and with what they are caked. If possible, clean mechanically. ie - with a brush or pipe cleaner. With soapy water if you like. Don't get the motor wet.
So I tried taking the fan off but I’m unable to
Has the screwdriver on the motor side of the vacuum motor keeps slipping out of the little slot in the middle of the shaft, So that means I physically am unable to take the motor apart to clean it, are there any other options of how I can clean it Or how I can take it apart?
If
You vacuum up fine dust such as drywall. If you had bearing issues or a seal or bag was bad when vacuuming. Examine vacuum look for an entry spot for dust.
It's a shop vac. Shop vacs are always abused. Run without filters or bags, used to clean construction debris which will puncture filters or bags. Used as a wet vac, then while still wet, used as a dry vac. Pretty sure that's what happened to my Fein vac. The plaster dust caked on the fans wasn't really dust anymore, it was more like solid plaster.
