aeoliandave
Having a rare night off and waiting for the thunderstorm I did a survey of all the vacuums on which I could reliably achieve an airtight seal, with one of the vacuum gauges I use on the workbench for player piano component testing. The readings were all taken via a 2.25" rubber ball pierced with a .25" brass nipple at the inlet hole, hose removed, with the same new paper or laundered cloth bag swapped from vac to vac in the case of duplicate models. While the gauge itself may be somewhat inaccurate (it may be in Mercury inches as opposed to Water inches) the readings are certainly relative to each other.
Airway 66 (1) 24.5
Airway 77 (2) 25.0, 25.0
Compact Electra (1) 25.1
Electrolux AP100(1) 23.5
Electrolux ZB30 (1) 24.1
Electrolux ZB55 (1) 24.1
Electrolux ZB89 (1) 25.1
Electrolux XXX (3) 20.9, 23.1, 23.5
Electrolux LX (4) 23.0, 23.0, 23.0, 23.2
Electrolux E (1) 23.9
Filter Queen 70 (1) 26.1
GE CP101E (1) 23.0
GE Roll-Easy R1 (1) 23.9
Hoover Portable Cleaning Center (1) 23.8
Hoover Tempo 450 (1) 23.5
Kenmore Rocket (1) 23.0
Plymouth (1) 23.0
Yes, the Filter Queen pulled the strongest, followed by the Compact, the Airways and the Canadian Electroluxs. Also noted is that the Canadian Electroluxs are the quietest operating vacuums by a long shot - they are a whispering zephyr compared to all the others, tho the LXs have the most pleasing subsonic hummmmmm, IMHO. In the cat's opinion as well as these quiet vacs are their favorites to rub up against in operation - I have even seen Dexter drape himself across the running ZB55...LOL
Its not my intention to start a thread about what beats what, which would be futile nonsense anyway. These are simply my test bench observations for the collective amusement of us all. It does tell me that one of the XXX's has a fan dust buildup to clean out, while the LX that gave a 23.2 reading is an original without the suction dial modification.
Gosh, I sure wish I could be in Omaha next week...
Could not resist its obvious charms and won a 1954 two tone blue Hoover Constellation Model 82 with hose last week. I am in need of an aluminum telescopic wand and all the matching blue nozzles if anyone can be so kind as to contact me anytime. I will be traveling across Pennsylvania/Ohio/Indiana/Illinois and the Minnesota/N Dakota midwest on my way to Winnipeg Manitoba in mid November. Looking very much forward to visiting Canton Ohio. Return trip will take me across Michigan. hint hint
Dave
Airway 66 (1) 24.5
GE CP101E (1) 23.0
Plymouth (1) 23.0
Dave
