fantomfan57
Hi, I came across this:
Q: I've had a Kenmore 3.9 hp canister vacuum for years, which is still in excellent condition, because I'm a bachelor and it doesn't get used much. But there is a growing 1-inch tear at the base of the plastic hose. The hose gets stressed especially at the base when I use the machine. What can I use to patch the rip?
A:
Ok I agree duct tape would work fine, if this was my project i would try Ace Hardware or Home Depot for shrink tubing (just slightly larger than the hose) this would allow it to slide over. Detach your hose slide a 4 inch piece of s-tubing centered over the split then use the heat from a hair dryer to shrink the tubing. This will be flexible and long lasting, good luck my fellow makeshifter.
Your thoughts?
A:
Your thoughts?
