Vacuette question
tom519
Long Island, New York
I took apart the gearcase on a vacuette recently, and am trying to figure out how to remove the fan blade. Also, there are 3 what look to be like bearings that fell out when I opened it (see picture), and I can't figure out where they go. Has anyone ever taken apart the gears in a vacuette before? How does the fan blade come off?
Tom, those are friction rollers, a type of clutch drive. They ride on the outside edge of the tapered slots in the slotted 'disc' next to them. In the forward push direction they ride up the inclines under centrifugal force and lock to the wheel's drive shaft so everything turns with the forward motion.
When you pull in reverse or stop pushing they are free to roll away from the shaft, which allows the fan axle to keep turning under inertia.
I would have expected to find a large fiber washer that presses against the clutch wheel to keep the rollers aligned with their inclines (?) and perhaps that's what we're seeing still on the left pressed-in axle bushing?
I hope you kept notes on the exact orientation of the parts, especially any spacer washers hidden in the old grease.
As for removing the fan, it is likely there is a cir-clip holding the screw shaft from backing out of the housing.
Highly recommend that you 'wash' the case and parts in a degreaser bath to clean away ALL the old grease and probably grit. Then it will be easier to determine what's holding the fan screw in place.
Be sure to replace with new lithium grease so the parts are well lubricated.
The small screw you removed is for setting the distance/depth of the fan on the screw shaft from the back plate so it does not contact the housing when reassembled. The fan is either seized from age or is in fact a screw on fan - I suspect there may even be a keyway.
But the screw shaft itself must be secured in place with a separate 'washer' or washers. As I say, probably a cir-clip.
Dave
Fan removal
Since you already removed the lock screw on your fan; you will probably need a friend to hold the fan securely, and not to high over some pillows. After you have done all this, take a small metal rod or screw driver and lighty tap the fulcrum in the middle of the fan until it falls off. Make sure the tool you use is a smaller diameter. The Hoover model 28 fan is a good subtitute to use if you can not find a vacuette fan.
THANKS Dave and Calem !! I got the friction rollers in place, and I got the fan blade off. It came off rather easily when I tapped on the fulcrum. Now I just need a Hoover 28 blade since one of the blades is broken on this one. But first I'll degrease all the parts and clean them up. Calem, is the diameter of the hole on the Hoover 28 blade the same as this one? Does it fit perfectly on the shaft? Is there a set screw on the Hoover 28, how does it stay on?
About fan
I'm pretty sure it is the same diameter, but a little tight. The hoover fan has a nut on the top of it and it's a little taller and not as wide, but it will fit and hold with a little fuss. But, most importantly, do not over tighten the four flange screws- IT Will BREAK THE FLANGES!!!
Calem, I just remembered I have a picture of a Hoover 28 fan blade that I had worked on a few years ago. It does look pretty similar. I see the screw on the top of it, I probably can take that off, once I get a blade.I
Hoover fan
I think you will probably have to tap it on too. It should be snug enough to hold by itself. If you can, please, post some photos of your vacuette?
