Using a sentria for commercial use
rainbowvacfane2
tracy ca
So I got this sentria for 25$ from my local vacuum shop because she was pretty beat up and it was missing the brush roll bottom plate and belt of course so I cleaned it up and I kinda want to use it for my job it would be perfect so what am asking is what do you guys think can I use it for commercial use I spoil my vacuums so I would be careful but how would the motor hold up
go for it!
The kirby is an EXCELLENT choice for commercial choice! It's a higher end royal basically, and it has the BEST filtration out of ANY (and I mean ANY) vacuum on the market today! the tech drive is a great alterative to and better than a self propelled system. I've used my kirby sentria to clean an office suite before, and it works wonders.
RE: Kirbycassic111 thank you
Thank you for the part number also oldskoolguy thank you for your input I just wanted to see what it would preform and how she would hold up
That's quite the amazing deal you got! Be careful with her if you're using your commercially since it is a direct air machine. Maybe consider upgrading to a bypass machine in the future.
I would verify the voltage of the building first with a plug-in voltmeter in random outlets before using the vacuum. Most industrial buildings run on 220v and that will cook that vacuum in less than a minute. If 220v you might need to buy a step-down transformer to convert 220v to 120v in order to use it.
If the voltage is safe to use, I would recommend gluing some strong magnets to the front of the brushroll to catch paperclips and thumbtacks and whatnot. Also like others have said, a longer, tougher, industrial vacuum cord would help too, since the outlets in offices and other industrial buildings are spaced few and far between.
I would concur with what others have said. Kirby makes a tough machine. Even though they're intended for home use, their construction is definitely industrial grade. When I was in elementary school, back in the early-mid '70s, my school had a Kirby Classic Omega to vacuum the library, which was the only carpeted space in the school.
Update
So today all the parts I neeeded came in and she had her first day I cleaned 4 offices 2 of them being fairly big and I started with a brand new bag IT ALREADY HAS A pound of stuff in the bag as far as the motor holding up to this use I see no reason why it won’t it ran it for about 40 mins straight and she got Luke warm it’s the perfect work vac thank you all for the input I will post pics and updates as they come
A Kirby used commercially shouldn't be a problem-you may have to try to find a supplier that can sell you the bags in bulk.In commercial use-the Kirby will fill them FAST!!!Wish a dump bag option was available for the "G" type Kirbys-would be good for this use.Or---Heaven forbid--try that horrible Keeler thing!!Bet it would clog under that type of use in moments!
Or get one of these!! I've often fantasized about being able to vacuum a space like that with the Pig, as much as I enjoy using it at home, it would be that much more satisfying in its natural environment. Its a beast that longs to once again free-range on the open glue-down prairie...
[this post was last edited: 11/18/2017-13:33]
Whenever commercial vacuums are discussed the "Pig" always comes up-have four of these monsters and LOVE them!!!!Its fun to use the Pig with the Volt powernozzle!And-yes,I have coupled a Kirby to the Pig!!!!Just like with my central vacuums.Awkward,but WORKS!!Would like to have the Pacific Steamex version of the Pig,too.
tolivac
Rex,
Among commercial vacuums, the Royal 311 Heavy Duty Commercial, produced from 1945 to 1987, is probably the most elusive since sales of straight-suction upright cleaners had been on a slow-but-sure decline since the 1930s, when revolving brush-equipped uprights started picking up sales.
Update
I decided to polish it up a little bit and I got a spare bag am ordering 18 bags from curcial vacuum because my frist bag is already half way full
Ben: With hard floors becoming more popular in homes-surprised Royal hasn't brought back their straight suction uprights-think hard floor householder would like them.I have a much older place-1972-that is WW carpet.
