Using a Kirby To Clean Your Computer?
kirbyclassiciii
Milwaukie, Oregon
How many of you here have ever attempted to use a Kirby or any other large vacuum cleaner to clean your computer, including the keyboard?
I believe with the Kirby it could perhaps suck the keys off the keyboard, correct?
Regards,
Ben Edge
Put the Kirby in the canister mode-use the "inflator-deflator" tool to clean the keys on the keyboard.Does well in getting the dust and crumbs from between the keys.for Kirbys that don't have inflator-deflator attachments-get a generic "micro" cleaning kit and use that on the hose of the Kirby.
Oh yes,setting the Kirby into the blower compressor mode-and blowing the dust out of the computer-you would have to do that outside-amazing how much dust gets sucked into the computer unit with its fans and blowers!and since the blower mode of the Kirby is low pressure and gentile-unlike a regular 100PSI compressor-would cause damage.The high pressure air could blast dirt INTO the computer parts-causing damage.
I do have a small compressor that I use sometimes but it's very noisy and I like the sound of the Kirby much better. I take the computer and Kirby out on the back patio, and clean away, I usually do this every three months.
I use the compressor mostly for my typewriters.
Yep, I did it in suck-mode though, using a paintbrush and holding the nozzle a few inches away, so it would not pull any parts of the motherboard, worked well and the computer lived until it was dismantled for upgrades... :)
I regularly clean my PC with a Kirby using a soft brush on the end of the hose I find it works great on keyboards although I did once loose the R key off my old laptop when I did not use the soft brush so lesson learnt on that one. As for the main tower I just get the baulk of dust out using the hoover and the rest I blow out using my Air compressor.
I vacuum out the dust from the internals of my PC with my 2007 Numatic Henry using the dusting brush. Works every time :)
Give us some information about it (maybe in a new thread in Off-Topic) and I'm sure some of us can help you if you want information.
