What upright vacuums do you find to have the most useable tools... and least useable?
I always thought the older uprights with the front, rear or pan converters had the most useable setup, as far as easiest to work with hoses and best attachment sets.
Many of the modern tool on board uprights I find the hoses to be practically useless. There is too much suction so the hose collapses.
My mom had a Kenmore Quick Clean bagless upright (Panasonic). It had the stretch hose that draped over the handle in a U shape. Sometimes I'd use the attachments on it but we rarely did (my mom would usually get mad if I tried to use them and tell me not to waste the time). But when I did, usually the machine would fall over on me whenever I put the crevice tool or dusting brush on and touched it to a surface. Very aggravating!
My grandma had a Hoover Elite and I don't remember it having this problem.
Also I've used a cheapo Bissell Powerforce bagless and it didn't do that either. It had a more rigid hose that wasn't as springy...
I also have a Kenmore Progressive upright and while its hose is pretty short, I find it to be fairly useable. There's a clip on the back that lowers the center of gravity so it doesn't tip as easily, or you can unclip if you need more hose. Also the other good thing is it has a 3 speed motor so you can slow the suction down, as well as a suction valve on the wand. I find the tools not all that great though, it has a tiny dusting brush with short scratchy bristles that slide off to make an upholstery tool with sharp edges.
My mom now has a newer Hoover Windtunnel 2 bagless upright, and I do find the hose useable on that. It also has a decent dusting brush that has fairly soft bristles.
I've never used a Sebo or Miele upright, but I bet they have great hoses and tools with them. And of course Kirbys I've noticed have a great hose setup. I believe they even have soft horsehair brushes too.
It just seems even if manufacturers had good tools on their canisters, they almost always skimped on the uprights - cheaper tools or less selection to use.
Also for some reason tool on board uprights tended to use proprietary tools so you can't just swap out 1 1/4" ones to use. Although many older ones did.
