beko1987
This jumped to the top of the pile recently, I tripped over it once too many times in the garage, so bought it home last week. It's creaking alot, so I thought a strip-down and clean was in order.
From Boost
From Boost
The remains of a bojack air freshener!
From Boost
Removed the bag door
From Boost
From Boost
Sadly the bag door is going the way of all the boosts I've ever had. Have one or two pieces of it though, will repair as best I can
From Boost
From Boost
Stripped out the rest of the bag compartment
From Boost
From Boost
From Boost
Wires next
From Boost
From Boost
From Boost
Then the tool holder. Tried to get the hose holder off, but the bottom screw rounded off on me, so had to leave it on
I have the missing piece, another bit to glue
From Boost
Fading much?
From Boost
From Boost
Moving down
From Boost
baseplate
From Boost
How the plastics should look, un-faded
From Boost
From Boost
This has had a Hoover Repair at some point (sticker on the handle), so that must be when they siliconed the fan case. It's something I always do, but never see on an un-touched cleaner
Belt guard
From Boost
From Boost
From Boost
From Boost
From Boost
Could finally get the wires out the way
From Boost
and pull the heart out
From Boost
Front room looked ok I thought (SWMBO was at work!)
Every screw
From Boost
The boost has a lean, but the brace looks ok. I have the one from my parts vac which stood up fine though, may compare and see if it helps
From Boost
Then it all got washed and put upstairs to dry. Just polished the hood, need to glaze and wax it next
From Boost
From Boost
From Boost
Will update when I next do anything. Going to try and get the motor sorted tomorrow night, so I can take it over to my mums and re silicone it together, and find a large cable-tie!
From Boost
From BoostThe remains of a bojack air freshener!
From BoostRemoved the bag door
From Boost
From BoostSadly the bag door is going the way of all the boosts I've ever had. Have one or two pieces of it though, will repair as best I can
From Boost
From BoostStripped out the rest of the bag compartment
From Boost
From Boost
From BoostWires next
From Boost
From Boost
From BoostThen the tool holder. Tried to get the hose holder off, but the bottom screw rounded off on me, so had to leave it on
From BoostFading much?
From Boost
From BoostMoving down
From Boostbaseplate
From BoostHow the plastics should look, un-faded
From Boost
From BoostThis has had a Hoover Repair at some point (sticker on the handle), so that must be when they siliconed the fan case. It's something I always do, but never see on an un-touched cleaner
Belt guard
From Boost
From Boost
From Boost
From Boost
From BoostCould finally get the wires out the way
From Boostand pull the heart out
From BoostFront room looked ok I thought (SWMBO was at work!)
Every screw
From BoostThe boost has a lean, but the brace looks ok. I have the one from my parts vac which stood up fine though, may compare and see if it helps
From BoostThen it all got washed and put upstairs to dry. Just polished the hood, need to glaze and wax it next
From Boost
From Boost
From BoostWill update when I next do anything. Going to try and get the motor sorted tomorrow night, so I can take it over to my mums and re silicone it together, and find a large cable-tie!
