tube needed for Air-Way Sani Clean
jackies
Hi,
We have an Air-Way Sani Clean that's probably about 15 years old. It has 2 pieces of metal tubing. The lower piece, the one you attach the carpet power attachment to, has a plastic part on the top where the upper piece fits into it. THe top piece has the little metal button that pushes in, fits into the plastic piece at the top of the lower piece, and you twist it about 1/4 turn to keep it in place.
The problem is that the plastic piece on the top of that lower piece of tubing is cracked, so the upper piece won't stay in.
I have taken it to our local vac repair store, but he doesn't have any tubing that will work with the Air-Way.
Does anyone have a spare part or a suggestion on where i might be able to get one? Let me know if you need a photo of the broken part and I can try to attach one.
Thanks,
Jackie
Try.....
Air-tec.com. They bought the patents for the older style attachments. They also sell bags that are extremely well made that will fit your machine. They make a machine that is vertually like the Sani-Clean.
PR-21
Bud Mattingly
