Tryin my best to fix my dial a matic 1149 on my own.
gj3476
Prosper,TX
Hey guys! I decided to take apart my dial a matic without any instructions to get to the motor and look at the carbon brushes. I unscrewed everything but what now? I’m trying to get the body off of the base.
Well I’m that close to the motor and I got the carbon brush and I don’t know what do y’all think? Please help!
Dial-A-Matic
As with most vacs start with the basics.On non power drive DAM remove bottom plate,brush & belt,hose between brush & bag,handle & cord assy,bag door.Then go further to the problem area.(Or as one vac guy told me years ago 'Take out every screw you can find and shake it'!) With condition of your motor you might need a parts vac or motor.With some DAMs motor is similar to Portable,Slimline & Swingette.Others will no more.
Good luck
And does anybody have an original handle screw for this machine? I got a different screw from the Home Depot and it doesn’t screw in all the way, not very firmly.
Big Headache!
I had a DAM a few years ago and took it apart to thoroughly clean it and get rid of the rotting foam inside. I just about lost my religion! That thing is a beast to work on.
