Tristar CXl Motor Teardown
Can you describe the extent of your knowledge?  e. g. Do you know how to get to the motor, etc.?  Does the motor have any symptoms?  Is their a grinding or squealing noise?
squealing noise
yes there is a squealing noise i got top fan shroud off then i took the two bolts out by the brushes but i cant get the peice off that goes over the rear bearing so i can grip the armiture and remove the fan nut ive serviced the motor in a lux af 1401B and a model 30
