Tristar CS question
ctvacman
CT
I recently won a basically new CS off eBay orig box manual tools etc... Literally was not used, upon turning it on I couldn't help but wonder if it really had the brushless motor. It did not do the slow start thing when turned on and it has the same pitch I found annoying on my guardian ultra. It's slightly quieter since it's made of metal, but still kinda pitchy.
So I guess I'm wondering if all CS's had the brushless motor or was it added awhile later. I have pictures of the motor. I looked closely and couldn't see brushes but then again I'm not an expert on this brand.
Colby
Unfortunately
I do not have a dealer near by otherwise I would have purchased from them, assuming the price is good.
Exactly
I didn't see wires either, that's what made me think that yes it is brushless. Didn't really take the motor out to look at another angle.
If it's like the Electrolux / Aerus motors the carbon brush is in a plastic housing in the plastic bridge over the end of the armature. There are no wires to the brushes, there is a spring underneath that makes the contact to the brush assembly.
The TriStar CS motor is NOT a brushless motor. It is made by Johnson Electric, & it does use carbon brushes. If you look under the motor field coil, you will see the brushes. It's very similar in design to a Domel motor & the Miele Vortex motor. A fellow member & close friend, Piano_God, has referenced to it's design a couple of times in postings here on Vacuumland.
Kirbylux and tolivac
Thanks for the clarification. I thought they needed a circuit board to operate.
Kinda pissed that many people on here said the CS is a brushless motor.
As far as I'm aware of, only two currently available portable vacuum cleaners made for domestic use have brushless switched reluctance motors. The newest model Delphin and the Rainbow. The now obsolete Dyson DC22 used a brushless motor as well, but I don't believe they sold well. The Dyson STICK VACS have brushless motors in them - but of course are not full size vacuums.
Tom
Just wondering....which motor manufacturer is making the Rainbow & Delphin switched-reluctance motors? Ametek Italia? And are they identical specs in regards to Waterlift & CFM ratings?
Tom
I was aware of those models using them. You're right the dyson dc22 did not sell well due to its tiny size and almost $800 price tag. I just read so many people on here saying the CS used a brushless motor, I was hesitant but believed it anyways. Oh well.
Tristar is made in the same plant as Aerus, they share parts in common, so I don't understand why anyone would think they use a brushless motor.
Exactly
That's what I thought was odd as well. Aerus would certainly use a brushless motor as well
Actually Rick A.:
That's not quite the case. You see, some of the Rexair brushless motor components are made in China. Evan Rogers showed me the Rainbow motor's rotor (we used to call it the armature), and it was plainly stamped Made In China. Rexair buys parts from suppliers just like everyone else.
Mike
Why would you have been surprised that Rexair's motors use Chinese components? Even Electro Motor, the former Electrolux motor manufacturer, states on their website their motors are made in Tennessee with components sourced from their Chinese plant.
I personally don't see anything wrong with it, or using Chinese motors, IF they can produce motors or motor components of comparable quality to European or American motor manufacturers.
Brushless motor last for a very long time and run efficiently. They also do not emit that black carbon dust which is said to be really bad to breath (not that anyone has died from it) but still it helps keep the final filter cleaner longer.
