Top loading bagged Beam?!
I quite like the design of these units. A good copy of an MD (but these older ones are without the onboard utility valve, making it possible to use a simple single-intake closed bag).
They are much less common labeled as Beam, but Beam has built them under the Eureka, Frigidaire, and Heatilator names. As well as, I believe, White-Westinghouse.
Vacuum devil
You now own or run a central vacuum shop? You have 2 channels and 1 is central vac based and the other is not.
I can only imagine Central vacs margins are far greater than repairing vacuums in a vacuum shop.
Is my assessment on what happened to your YouTube channels correct.
This is sort of off topic but I'm asking.
Thanks.
