madabouthoovers
- Joined
- Aug 14, 2012
- Messages
- 2,351
This is another of the haul of 11 I got a few days back, and was not in very good working order.
It was stripped down competely for a clean out as someone had either used it with no bag or it had had a bag burst in the past.
Manufactured Jan 1994, this is the TP 2 800W with bag indicator. It was absolutely filthy inside on stripping it down, the motor housing was full of dust and dirt and the filters totally clogged, both pre and post motor. The motor itself seems to be a bit on the noisy side having been subjected to severe dust abuse, but seems to be OK otherwise.
The only problem with it that I cant work out is that it has a very piercing whistle when working, in upright mode with the hose plugged into the base. But if the hose is moved about the whistle stops, so its airway related - although all the airways are clear. If the hose is pulled out of the base, the whistle stops as well. Its as if there is something causing resonance somewhere in the base pipes, but as yet I cant identify it - only that if the hose is removed from its guide on the back, when vaccing in the upright position then the whistle stops. Very odd indeed.
The belt needs replacing as it suffers from the usual problem of the brushroll stopping when vaccing carpet. It still seems to have the original belt on it as it says "turbopower 2" on the belt. No wonder its slipping and stretched if the belt is 19 years old.
Here's some pics of it
