phaeton
I just picked this up and it seems to be complete and original. The tag that is attached indicated it is from "The Hoover Suction Sweeper". The bag while in poor condition appears to be the original bag. The cord also looks original with the screw-in lamp socket connector. The commutator looks strangely as if the vacuum was only run a short amount of time. It has been used as there someone has stapled the belt back together. The little foot pad for the on/off switch is missing. I will have to lubricate the lower bearing before I run the the vacuum as it is a bit stiff when turning the fan by hand. That will be a project for later in the week and I will add the results to this post. I will not do anything other that make the little 103 run as it is cosmetically okay for me the way it is.
