After a minute or two of hesitation, I got one of these at salvage price with some other machines. When plugged in, it ran but made some ominous clattering sounds. Upon inspection back at the vacuum cleaner hospital, I found that half of the bottom end was worn out. One of the bearing plates had failed and ruined the brushrolls on one side.
This is a Model U8144-900 and even though only eight years old, parts availability is limited. The counter-rotating brush rolls are lefts and rights in two opposing pairs. Of the damaged brush rolls, one was very badly shot but the other was salvageable. HESCO had one brush roll but not the other. After studying their parts list, I decided the one they were out of was the one I needed the more badly. I went ahead and ordered it, thinking I could rework it somehow. When the parts arrived, I discovered that the one they sent was the one I needed the most so I either misread the catalog or they had it misidentified.
Some of the screw holes in the plastic bottom end were stripped or cracked, so I had to repair them with liquid epoxy or rebuild them with epoxy putty.
The plastic tool compartment door was missing but that is one of the parts that HESCO still had. Fortunately, they also still have the bearing plates. This is a critical part on this machine. Fortunately, the parts for it are relatively inexpensive.
For this machine, I have both a bagless dirt capture bin with pleated element filter and a separate capture bin that takes the HEPA Y bag within.
It's all back together and running now. I'm not sure what to do with it; it's not my line of country as a keeper and I'm not sure I want to sell it to someone as a daily user. Mostly, I worked on this machine out of curiosity and challenge.
Panasonic and Kenmore (built together at the same factory?) both offered dual brushroll machines similar to this at one time. I haven't worked on any of these.
