The Hoover LINX Cordless Stick Vac
We had quite an accumulation of reward points on our credit card that we wanted to use up, so the Hoover Linx cordless stick vac was one of the items that we sent for. It's nicely designed, has surprising performance, and is more than a better replacement for our ailing Electrolux Pronto stick vac. It runs for about 15 minutes on a charge, without losing power as you use it! This is more than ample time to take care of traffic areas in our home, the tile floor in the kitchen and breakfast areas, and a doggy snack crumbs in the familyroom. We are quite surprised by the power and the revolving brush and it actually fluffs the nap of the wall to wall as you vacuum. It definitely out-performs the Electrolux Pronto that we had for about five years. My Mom, at 84, loves it and uses it regularly, finding it a pleasure to use. Don't misunderstand....this is a stick vac, and as Sam indicated, should not be your only vacuum! We are quite pleased with it and now also have the hand vac. The hand vac is less pleasing, but does have more than enough suction. The nozzle needs improvement for certain. I agree with HS and will continue to recommend the Hoover Linx stick vac ! The only dissappointment is that it is NOT made in North Canton by the Hoover Company that we all knew and loved!
