The Air-Way Super Chief Arrives!!
Dave,
Those go to the Air-Way Sanitizor model 66, (circa. 1949), which is blue to match your tools. They did indeed slide onto the floor nozzle and were quite effective.
People at the time and still today, rave about the felt floor pad. The bristled attachment worked fairly efficiently considering the time frame. We know today that a dental notch brush strip or shorter brush row in the front work better.
The steel bars are different from the round rods. I think, and I emphasize, THINK, the steel bars are from earlier models probably starting with the model F from 1928.
And, yes, you are correct, the dusting brush did slide onto the crevice tool. The dusting brush did not become it's own entity until later in production.
I wanted to post a pic of your Green Goddess that I had access too, but had problems doing so, so I am glad you did. Your model is very nice! I've seen several over the years and most have not aged as well.
But, we have to keep in mind these vacuums are from an era long passed by. They also were made of materials that probably were not designed to last 75 years!
Hoovers, arguably, seem to last somewhat better. My Hoover model 150 from somewhere from 1936 to 1939 seems to be far sturdier and interestingly enough, you can still find other 150's out there to get parts from!
Try finding a bumper for a Air-Way DirtMaster! Or an outer cloth bag. Or even disposable paper bags for that matter. I suppose this is why the Air-Way vacuums are so collectible and rare.
Thanks for the great pics and now go find a model 66!
Charlie W.
Further delving reveals the conundrum that perplexes me.
Charlie, I do have two each of the Models 55, 66 and 77.
I'm sure you meant to type 55 aka the Hydrant.
Now, I have tools and tool bags and caddies for all three models but I suspect the tools that came with my 55 are actually from a 66, or a late 55, when a change was made to produce separate all in one aluminum cast nozzle bodies - with the felt polishing pad a clip-on interchangeable attachment...
...because I do not have the slim upholstery nozzle these 55 'feet' are designed to slide on to, as shown in this page from the 55 manual.
Also, the wands & floor nozzles/tools that came with my 55s are not compatible with the 66/77/88 etc wands - and vice versa - in that the 55 tool flange ring is set further from the wand end and the end taper is larger. The right tools on the right J wands go together only one way. The retaining tab is different as well.
Curiouser and curiouser...Inquiring minds need to know. :-)
Dave
Oh wait!
I do have that upholstery nozzle, after all. It came with a second 55 snap-on caddy bag I snatched up last year. Silly me. I shall correct the contents of the 55 saddlebag forthwith...
I also have a triangular Air-Way dusting brush ( like the dirty gray one in the picture) in black rubber, which colour matches the 55 floor tool bumpers. Yippee!
All it takes is a nudge to the noggin that threads like this inflict to make connections that bring it all together from the various spare parts bins, nooks and crannies.
Thanks, Charlie.
Dave
Here's what I mean about the wand to tool difference. As to whether this change was made during the run of the 55 or began with the 66, I simply do not know.
You can see the upper wand has a longer end beyond the clamp ring.
The top tools will fit only on the top wand and the lower only on the lower wand.
The bore inside the lower tools is only as deep as the wand end and so the tools are not interchangeable on the wands.
Wow Charlie,
Just beautiful. I remember how happy you were when you got that machine. All of the work you have put into the restoration was sure worth it. I too hope that we will be able to see it in Austin. Your entire collection is fantastic.
Terry
Terry,
Due to some shipping issues, I probably won't bring it to Austin. When a convention is drivable for me, then I will bring all of them.
It is just too risky to ship. If anything gets banged and broken, I'll be SOL!
See you soon!
Charlie
My apologies for inadvertently hijacking Charlie's thread.
I do want to get in this final nozzle/wand picture. Two types of latches for securing the nozzles so that they can swivel freely. The early one is a simple screwed on and adjustable tab and the other is a spring-loaded 'hook' catch. As I observe, the two wand ends are different enough in length, diameter and taper that the nozzles will not fit on each other's wands.
More information on this and other things 55/66 I will continue over on Pete's new 55 thread...
http://www.vacuumland.org/TD/THREADS/VINTAGE/8852.htm?2
