Synthetic bags
My mind goes to
Compact/TriStar HEPA bags, but I don't think they're quite large enough. Look at you getting me all crafty minded 😂 it's been a lot of trial and error with making and modifying bags to fit old stuff. For a point of reference, Simplicity S bags will fit a Eureka Whisk with a little trimming! 😆
Good luck! Can't wait to see what you come up with
No…but I figured you just need enough synthetic bag filtration material to be able to cut it to fit the full circumference of the Swivel Top’s tub. So I was just recommending the largest hepa bags that might give you enough material to create a large enough bag.
Understood.
I am thinking about the central AC bags. I noticed they are pricier.
I will respond later with the results.
Thanks, and I appreciate your suggestion. I also welcome any other suggestions from the membership.
Why not try using a Kirby HEPA Cloth bag? I think that would work since it's one of the largest upright bags on the market. Take off the cardboard collar, close the hole up with staples or glue, and then cut the side of the bag open and line the GE cloth motor bag with it.
