wyaple
The first two measurements were easy to get, the last one (CFM at the nozzle) required me to build an airflow box. I think this pic should easily illustrate where and by how much CFM is lost in this machine. Based on the massive airflow loss at the rug plate, I am rather disappointed and confused at the performance of this cleaner.
From the base of the machine through the very long hose to the head assembly, there is a loss of 114-97 = 17 CFM. From the hose connection to the nozzle, there is a loss of 97-42 = 55 CFM.
Total airflow losses from the main body to the power nozzle (held at a 45 degree angle to the floor) is 114-42 = 72 CFM or about 63% of the original airflow.
Last note: the rug plate opening is slightly larger than average (about 26 square inches), but CFM density is far, far below average, about 1.6 CFM/Sq. In. If you ever wondered if this expensive 12 Amp beast was capable of deep cleaning, I would have a hard time recommending it due to the massive airflow loss experienced at the plastic rug plate.
Bill
Bill
